December 20, 2025, 06:34:31 PM *
Poll
Question: funny running
virago - 0 (0%)
yamaha - 1 (100%)
Total Voters: 1
Author Topic: virago 700  (Read 3506 times)
richie
« on: July 28, 2011, 04:07:27 PM »
hi i have had this bike for some time but just finished converting to trike. the problem is that it only seems to run on the rear cylinder until warmed right up, i have good spark and compresion and the air lines are clear any thoughts or advise thanks
toad
« Reply #1 on: July 28, 2011, 09:03:30 PM »
An air leak that,s being sealed under heat expansion check the rubber inlet manifold their prone to hardening and splitting Wink
« Reply #2 on: July 29, 2011, 01:43:34 PM »
possibly the black box. Does the rev counter work ok when the rear cylinder is running rough?
Hagar
« Reply #3 on: July 29, 2011, 04:40:31 PM »
Try looking round on here  ........   http://viragotechforum.com  the site is a bit slow but well worth a look , loosing a pot  front/rear is quite a comman problem , but there seem to be lots of causes , from a weak battery to air leaks in the rubber boots that hold the carbs on , my rear would quit at 3500/4000 rpm , spent god knows how much trying to sort it , turned out it was the alarm I'd had fitted ... I only found out when the box with the alarm in sheared off and went walkies on the A14 , had to bypass the alarm plug  ( well me and the RAC man )  ....  went like a good'n after that  ....
  ..  Hagar  ..
richie
« Reply #4 on: July 30, 2011, 10:11:11 AM »
hi thanks for the info found an air leak at the inlet manifold will change that and let you know if it works. again cheers
richie
« Reply #5 on: July 30, 2011, 01:12:21 PM »
running like a dream thanks
« Reply #6 on: July 30, 2011, 10:45:14 PM »
Another small miracle performed.
Next!
« Reply #7 on: July 31, 2011, 07:33:27 PM »
IT LIVES, IT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Cheesy Cheesy Cheesy Cheesy
