March 05, 2026, 07:24:20 AM
Bike Tech
xj600n.....................what engine
Topic: xj600n.....................what engine (Read 3238 times)
klogan45
July 16, 2011, 02:13:21 PM »
Hi guys I said a while back that I had been given an XJ600N on an R plate with a dodgy gerabox. I'm having a look around for an engine, no rush to buy yet but I want to be prepared, like the good little boy scout I'm not. The question is what XJ engines will fit? Ive seen xj 600s, diversion, pre diversion etc,etc.
Please help coz I'm really confused at the moment as to what will fit what.
Thanks
Regards
K
andbolt0
Re: xj600n.....................what engine
July 26, 2011, 09:09:24 PM »
i got a diversion 600 engine and all the bits to make it go came outof a running bike no smoke or rattles etc £100 if yer interestednear manchester thanks andy
klogan45
August 03, 2011, 08:32:02 AM »
Hello Andy, thanks for the info about your engine I'll have to check out the cost of getting it down here via courier or someone. I'm not ready for an engine just at the mo and things are a 'bit tight' just now. I'll contact you when I'm ready and if you've still got it we'll do the deal.
Thanks again
Regards
K
madron
August 03, 2011, 04:38:15 PM »
im not sure but think pre diversion (xj) were upright motors but diversions were on a forward slope as carbs are vertical on them i would just check before spending i buit a divi chop and there different to xj motors
toad
August 04, 2011, 07:03:41 PM »
If you give me the first 3/4 digits of your chassis/engine number either will do i can tell you what will and wont fit cheers toad.
klogan45
August 04, 2011, 09:45:20 PM »
Just got this one Toad, I'll post the numbers in the morning.
Thanks
Regards
K
klogan45
Reply #6 on:
August 05, 2011, 04:34:41 PM »
Hello toad I've got the numbers for you.
Frame number 4BR248
Thanks in advance for your help, I really appreciate it.
Regards
K
