May 16, 2026, 03:22:14 AM *
Pages: 1 [2]
Author Topic: Pedals  (Read 5220 times)
« Reply #15 on: July 15, 2011, 11:50:39 AM »
The Tang also needs to be positioned where it will give maximum amount of travel to the operating rod before the pedal is depressed to far.
This will depend a far bit on your riding position, because your seating position will affect the movement of your foot!
For mid controls i have the arm angled at around 40 - 45 deg, i find then that i can achieve full rod travel before my foot is horizontal. In fact on the Kawasaki, i can lock the brakes up within 10 deg of pedal travel.
« Reply #16 on: July 15, 2011, 11:52:28 AM »
Thats brill thanks alot for taking the trouble to explin ,it will help a lot  Grin
No problem, i got some more pics but Mrs T wants the computer now, so i`ll add them later.
« Reply #17 on: July 17, 2011, 10:57:19 AM »
Here you go then, pedals........ Don`t copy and print these, they are not to scale.
If anyone needs proper pics that are to scale, I can add pdf files for downloading  Wink
Both pedals are 6:1 ratio and would use a 30mm OD pivot, the holes for the pads, or in this case, toe pegs would be drilled to 6.5mm then tapped to 8mm.
« Reply #18 on: July 17, 2011, 09:59:33 PM »
Why don't some of you clever peeps live down here?  I want a solution for my touring pegs, at present attached to the engine bars but not really doing it for me any more.
« Last Edit: July 18, 2011, 12:45:38 PM by BikerGran » Logged
« Reply #19 on: July 18, 2011, 09:03:42 AM »
PDF files for download. Make sure your printer settings are not scaled, these need to be printed 1:1 scale. (files carry the MMM watermark)
Pages: 1 [2]
