May 17, 2026, 05:06:55 PM
General Tech
Wiring types
Topic: Wiring types (Read 3534 times)
RODeo
Wiring types
June 27, 2011, 04:36:57 AM »
After looking at the wotsits rebuild on wiring,reminded me....Ive just got some cable from VWP that is really thin and is apparently used on new car looms nowadays . It is very easy to 'fish' through the frame and bars. To be honest it is so thin that I just couldnt believe it would take the 11 amps its rated at. They do various gauges for higher amps and loads of colours.
Perhaps this is something bikes use already?
Rod
Re: Wiring types
June 27, 2011, 03:34:40 PM »
Is it the thin wall stuff?
Thin wall cable has been around for a while now, I have yet to use it, purely `cos it was a fair bit dearer than `normal` cable.
As the name suggests, the difference is in the wall rather than the wire, the wall being half the thickness it used to be, but gives improved protection and insulation due to chemical changes in the plastic used.
WAYNE999
Re: Wiring types
June 27, 2011, 07:27:41 PM »
the stuff i bought for wotsit is thinwall and rated at 16amp i got 10 5 metre lengths all different colours for 15 quid we'll see if it melts when we get it running
RODeo
Re: Wiring types
June 28, 2011, 04:13:53 AM »
tb.....Yes youre right,but apparently it will also take more amps than a similar size cable.
Re: Wiring types
June 28, 2011, 11:28:49 PM »
Quote from: RODeo on June 28, 2011, 04:13:53 AM
The thinner wall will mean the cable will release any heat build up more quickly.
http://www.choppit.co.uk
