hi rob,i just wandered because i noticed you were using the origanal bike lights and indicators on the back do you have any probs with mot, i would prefer to do the same as i think the exstra lights i have put on the back may be draining my battery i have put a new battery on but when i go out any where and stop when i come to start the trike again its as if the battery drained and can not start it off the button have just brought a multimeter and will check the charging system later to day to see if there is a prob there.all the best zak
Didn`t notice this before Zak. It may be a Viagra quirk. If I leave mine standing, with a normal lead acid battery, all connected up, then after two weeks the battery is sulphated and unuseable. I bought a gel battery and when I leave her standing, even only for a day, I disconnect the battery (there`s a terminal in the main power wire just in front of the battery).
