May 17, 2026, 08:04:15 AM *
Author Topic: Manifolds  (Read 5446 times)
« on: June 05, 2011, 09:54:25 PM »
Terry T popped up to see me today witha little project that needed welding.
He designed and made the parts to stick a Weber carb on his goldwing trike.
All Alunmium box tube and plate so I had a go at tigging em up!
He made a really great and accurate wooden jig to allow me to tack em together and then weld weld weld weld weld.
Bit awkward in places and I could have really done with a larger tungsten (used a 2.4 but a 3.2 would have been better)
Anyhow Terry was happy with the result.
So we did a a couple more!  Grin
IMAG0707 by Shed Hobbit, on Flickr
IMAG0710 by Shed Hobbit, on Flickr
IMAG0716 by Shed Hobbit, on Flickr
IMAG0717 by Shed Hobbit, on Flickr
IMAG0712 by Shed Hobbit, on Flickr
http://www.choppit.co.uk
RODeo
« Reply #1 on: June 06, 2011, 04:46:51 PM »
Nice welds!
toad
« Reply #2 on: June 06, 2011, 06:12:31 PM »
WHO,S DESIGN?Huh?? http://www.mankymonkeymotors.co.uk/forum/index.php?topic=8947.msg104731#msg104731
« Reply #3 on: June 06, 2011, 06:19:10 PM »
Yes i am well pleased.Thanks again Iain
the original idear was Toads. a member he made one but for the 1200 and the 1000 is slightly differrent which meant altering the frame.so i altered it. made the jig and came up with this.
Thanks again to Toad for the 1st pattern manifold.and Iain for welding my manifolds  Smiley
« Reply #4 on: June 06, 2011, 06:21:04 PM »
You just beat to this toad thanks again
« Reply #5 on: June 14, 2011, 10:40:14 PM »
just fitted single carb convertion to trike.
thanks again to toad for the 1st one and the idear.
and ByzMax for welding up the altered ones i came up with
carb and manifold
fitted on trike
all back together
« Reply #6 on: June 14, 2011, 10:46:16 PM »
That looks impressive Terry. Have you tried it out yet?
« Reply #7 on: June 14, 2011, 10:55:27 PM »
Not properly yet Andy.seams to tick over ok but hesitates on acceleration.but a leaking diaphragm and blowing exhaust dont help.they been fixed know. so will try again tomorrow
« Reply #8 on: June 15, 2011, 11:41:43 PM »
Looks great.  Grin
hornet6
« Reply #9 on: June 16, 2011, 08:13:41 PM »
sterling job to all involved....looks great
no projects ever finished
« Reply #10 on: July 21, 2011, 08:40:18 PM »
update on single carb conversion.
i have decided to shelve the idear for the time being as i need to sort the jetting out.
so i re checked the originale carbs out. cleaned the sliders made a template and checked the float levels.
now i had done these just before i took them of set up with a steel rule.with this template they were about 2mm out  Huh. so reset them and put the carbs back together. will take the weber of over the weekend and refit the goldwing stock carbs.
i just want to ride it and not keep sorting things out.plus the garage is getting a bit full with another project for the winter
carb float setting template
