May 01, 2026, 09:11:11 AM *
Pages: 1 ... 54 55 [56] 57 58 ... 70
Author Topic: hillman superminx 1962  (Read 397867 times)
« Reply #825 on: May 11, 2013, 09:15:35 PM »
MOT rebooked?  Smiley
« Reply #826 on: May 11, 2013, 09:16:45 PM »
no not yet!!!!
rather knackered after nearly a whole day on it!!!!
« Reply #827 on: May 14, 2013, 04:44:08 PM »
i've tested the servo!!! with the dyson
taped over the master cylinder end, held hose on vacumm point, pushrod end push's in easily, remove hose very hard to push in, so servo ok, next is mastercylinder.
« Reply #828 on: May 14, 2013, 07:38:22 PM »
Brilliant! Lateral thinking at it's best.
« Reply #829 on: May 14, 2013, 09:44:57 PM »
ford master cylinder, where should the pipes go? as i think they're not correct.
« Reply #830 on: May 14, 2013, 09:53:22 PM »
ford  Undecided Undecided off what ?
« Reply #831 on: May 14, 2013, 09:56:44 PM »
sierra i believe.
« Reply #832 on: May 15, 2013, 07:14:54 AM »
I believe the front pipes go to the front brakes (one for each side) the rear to the rear usually via a PLV
« Last Edit: May 15, 2013, 07:23:44 AM by Old Newbie » Logged
« Reply #833 on: May 15, 2013, 07:17:47 AM »
One nearest the back is back brakes, 2 at the front are front brakes.
« Reply #834 on: May 15, 2013, 09:41:25 AM »
PLV -Parking Lot Vulture?
http://www.acronymfinder.com/PLV.html
« Reply #835 on: May 15, 2013, 12:13:58 PM »
Pressure Limiting Valve . It's big block mounted lowdown on a Sierra inner wing and also incorporates an anti rear lock up valve. It's pain to use in anything else as it's all geared to Sierra weight and movement. I've fitted complete Sierra systems to kit cars / rods  without using it and they've been fine.
« Reply #836 on: May 15, 2013, 04:17:22 PM »
cheers guys, need to get back onto this pronto for retest on saturday, but mojo lacking!!!
« Reply #837 on: May 18, 2013, 07:51:15 AM »
Hope you got your mojo back and the retest goes ok. Smiley
« Reply #838 on: May 18, 2013, 07:53:29 AM »
best of luck with the man ,,that can say yes,,, Wink Wink
« Reply #839 on: May 18, 2013, 08:45:40 AM »
no retest today, still in bits.
