« Reply #360 on: February 10, 2012, 11:36:44 PM » |
not sure yet.
« Reply #361 on: February 12, 2012, 06:32:59 PM » |
well they're out, drilled the peened over bit, crank the molegrips on and they came undone realy easy!!!!  once drilled the new studs will sit lovely, as theres plenty of meat there, also flat. not got a picture of the back. (doh!!!)  cheers everyone.
« Reply #362 on: February 12, 2012, 06:38:33 PM » |
So why are you changing the studs Chris?
« Reply #363 on: February 12, 2012, 06:47:11 PM » |
they're not long enough, and there a strange size, 5/16 something or other.
i'm putting 7/16" studs in.
« Reply #364 on: February 19, 2012, 10:04:05 PM » |
laid under hillman today getting burnt erm no welding!!! rear spring hangers finished and painted, gearbox x-member finished and painted. engine out next for a clean up&paint. finish welding in engine bay then a splash of paint.
« Reply #365 on: February 19, 2012, 11:02:58 PM » |
Good to see you getting stuck in after the recent ups & downs Chris  Err, don't suppose you've got any dust covers for the front wheels? (the domed caps in the centres).
« Reply #366 on: February 19, 2012, 11:14:25 PM » |
grease caps?
« Reply #367 on: February 19, 2012, 11:20:00 PM » |
Aye, that's them. About 2 1/2" diameter.
« Reply #368 on: February 19, 2012, 11:27:51 PM » |
i'll have a look, then give you a size.
the ones on austin beam axle actualy hold the outer bearing, held on through wheel studs!!!
« Reply #369 on: February 19, 2012, 11:54:13 PM » |
Weird -the bearings, not you.
« Reply #370 on: February 22, 2012, 10:36:03 PM » |
no i am weird!!!  caps are 48-49mm across.
« Reply #371 on: February 22, 2012, 10:40:59 PM » |
Too small, but thanks anyway mate.
« Reply #372 on: February 23, 2012, 12:01:18 AM » |
got another clutch release arm, lets hope its the correct one this time. also got some new 15" wheels, to re-centre. for rear. brand new £15 each free p&p!!!! 15x7
« Reply #373 on: February 23, 2012, 09:32:38 PM » |
engine & box out, split, new clutch arm fitted, put back together and its the correct one yippee thats something not to worry about.
« Reply #374 on: February 23, 2012, 10:03:28 PM » |
Weller 8 spokes? Where'd you find 'em for that price?!
