April 29, 2026, 07:43:23 PM *
Pages: 1 ... 22 23 [24] 25 26 ... 70
Author Topic: hillman superminx 1962  (Read 391879 times)
« Reply #345 on: January 29, 2012, 09:36:39 AM »
I seem to have spent my life cutting things up with hacksaws & only fairly recently switched to using a cutting disc on an angle grinder -saves a hell of a lot of time & effort, but creates so much mess! Now I permanently smell of grinding dust.
Pitman arms are usually cast aren't they. I can never remember -can you weld a casting, but not a forging, or the other way round?
« Last Edit: January 29, 2012, 11:07:53 AM by Manky Monkey » Logged
steve brock
« Reply #346 on: January 29, 2012, 11:03:49 AM »
I started with files n hacksaws then grinding discs and now lasers! I wonder what's next? Smiley
« Reply #347 on: January 29, 2012, 11:08:30 AM »
Light sabres!
« Reply #348 on: January 29, 2012, 11:51:22 AM »
weld a forgeing
steve brock
« Reply #349 on: January 29, 2012, 01:09:35 PM »
A finger tip light sabre perfect. Smiley
« Reply #350 on: January 29, 2012, 01:41:29 PM »
cheers, thought you could weld a forging.
but your not suppose to weld any steering part regarding mot etc!!! Wink Grin
« Reply #351 on: February 06, 2012, 09:10:52 PM »
hi,
need help on removing wheel studs, austin 10 hubs.
do these need pressing out? unscrew?
not a very good pic.
cheers chris.
« Reply #352 on: February 06, 2012, 11:27:01 PM »
Usually a press fit -the ends of the studs are splined to grip the hole as they're pressed in.
I'd recommend SpeedShack in London for replacement studs
http://www.speedshack.co.uk/
« Reply #353 on: February 09, 2012, 01:09:54 PM »
steering box mounted, column half sorted, front shocks arrived today, along with new spring shackles.
just got to get some mojo going as i've been of work all this week.
« Reply #354 on: February 09, 2012, 09:35:16 PM »
Piccies!
« Reply #355 on: February 10, 2012, 01:14:53 PM »
i'll take some later when theres a bit more to see(hopefully!!!)
« Reply #356 on: February 10, 2012, 09:54:41 PM »
here where the column, steering linkage etc will live.
everything is only mocked up at present, will have lots of welding,finishing once engine is out.
whats that i spot poking through inner wing!!!
looking underneath!
« Reply #357 on: February 10, 2012, 11:20:02 PM »
Fenderwell headers! Gonna be a proper gasser then! Did they come with the engine?
« Reply #358 on: February 10, 2012, 11:25:51 PM »
nope, they were bought for the buick v6 that i did'nt get.
« Reply #359 on: February 10, 2012, 11:28:44 PM »
Gonna paint them white? Seems to be the traditional colour.
