April 19, 2024, 05:42:48 AM *
Pages: 1 ... 25 26 [27] 28
Author Topic: Archie's Volksrod  (Read 90082 times)
« Reply #390 on: October 03, 2020, 11:27:30 AM »
Had a few days off over the last month but still been plugging away slowly. Was having a nightmare on deciding on how the cooking would work. On these the fan is on the back of the dynamo in a housing. Due to the body drop the housing was hitting the body. I spent ages looking at running it open, different oil coolers, running squirrel fans etc. In the end I just cut it out, shaped the grill and stick it back in. It means I can run the engine with stock bits and the fan housing site in line with the back window so Is aesthetically pleasing.
53-EFE8-C8-B78-F-4492-A899-AB6-DCA772-D56" border="0
480661-FD-B112-4-F53-86-AC-7-A12610-BC303" border="0
8-E33241-F-F912-421-D-B25-B-C22190032887" border="0
127813-DA-6-E41-4-D3-A-94-F5-5-CFE79781317" border="0
0249-D92-E-73-D8-4-FC5-98-A1-F3712-D501980" border="0
« Reply #391 on: October 03, 2020, 02:12:41 PM »
Liking that keep going. Smiley
« Reply #392 on: October 04, 2020, 10:10:36 AM »
What's a squirrel fan?
« Last Edit: October 04, 2020, 10:16:29 AM by Manky Monkey » Logged
« Reply #393 on: October 04, 2020, 06:31:47 PM »
They’re smaller ones which are normally used in drag racing. No idea why called a squirrel fan? They squirrel the air away maybe?
« Reply #394 on: October 04, 2020, 10:17:43 PM »
Aah, so not powered by rodents running in a wheel then.
« Reply #395 on: October 05, 2020, 07:39:50 AM »
the racing fans arent ideal for normal traffic. dont really move enough air at idle or lower revs
« Reply #396 on: October 17, 2020, 08:21:12 AM »
Starting to get the bulkhead finished. I made up a piece with a ridge so it could be spotted in to the existing bit. Then messed up cutting the existing bit so now it’s just welded where it can be. Doh.
C1-DC9938-F300-4-F19-B02-D-8-FB237570612" border="0
764-BE5-C7-5-A9-D-4146-9-D1-D-BD76-AE0-E72-AE" border="0
[img width= height= alt=77-BEFF96-899-D-4747-98-A2-FF6-CB303-BE39" border="0]https://i.ibb.co/JsDcJWD/77-BEFF96-899-D-4747-98-A2-FF6-CB303-BE39.jpg[/img]
<a target='_blank' href='https://imgbb.com/'>pic uploader[/url]
It’s amazing how rigid the car is now, considering you used to be able to push it and it wobbled like a jelly
« Reply #397 on: October 17, 2020, 08:50:42 AM »
Is the body still bolted to the floor pan or welded now?
« Reply #398 on: October 17, 2020, 09:29:54 AM »
It’s bolted so the plan is to split it next month and get all the welding on the body done. It’ll be easier without the floor pan etc in the way.
Then I can also work on the pan without a body in the way too. Might be fairly together by the end of the year maybe
« Reply #399 on: October 18, 2020, 11:08:11 AM »
Bet you'll be on the road before me!
It'll be cool to have some driving buddies next year Smiley
« Reply #400 on: November 22, 2020, 06:24:25 PM »
Again forgotten where I am with this. Waiting on some steering components I ordered in September.
I’ve started on the bonnet latch, as it had nothing due to being all cut out. I did a tube with the latch off the front beam. I was going to do 2 but it’s sturdy enough you can lift the car off the ground, so will probably leave it / tidy it up when the bodies off. I’ve got to make a bonnet cable guide too as that’s been cut away, so the cables not under tension meaning the latch isn’t latching properly.
550643-EF-FD98-4434-A14-F-7-DA758-CDCACE" border="0
4-B596413-C148-4156-920-B-742-BB48-F786-C" border="0
« Reply #401 on: November 22, 2020, 06:26:37 PM »
The body is a bit twisted/ on the wonk hence it looking not parallel to the beam, but it catches perfectly
A friend folded me up the seat raisers I needed, so I should be able to get the passenger seat in this week, and redo the drivers ones which are a bit over kill.
« Reply #402 on: November 22, 2020, 06:29:46 PM »
I also sorted out the big hole in the drivers door and smoothed out the top hinge. Unfortunately the door latch has taken a bit of a beating so needs replacing as it’s not springy anymore.
AE5-A4-F4-F-9-E74-45-E1-8175-86-A8-B0-AB6-D9-A" border="0
35-C5-F78-E-89-A6-420-C-8-F7-B-5-FEFC3937-FD0" border="0
[img width= height= alt=9-ADB1857-0716-4581-86-F0-91-BA021490-D9" border="0]https://i.ibb.co/2qBgPC7/9-ADB1857-0716-4581-86-F0-91-BA021490-D9.jpg[/img]
CFF2-F189-E240-4-C60-8-CA8-26-DBA3-C80-D14" border="0
92474603-59-C1-41-A7-858-C-8-DEB3-C4-E7-F36" border="0
2-BB78-A2-B-1275-4-EAD-A276-40-E1-CB5-D02-D3" border="0
« Reply #403 on: November 22, 2020, 10:37:26 PM »
Lovely handles. 👍
« Reply #404 on: November 25, 2020, 07:40:58 PM »
Had some plate folded up to act as a seat raiser. Got the passenger seat bolted in and sliding. Need to get some spreader plates welded underneath, but mock-up is good.
4-F210067-95-D5-474-B-95-A8-CA42601-C1-DBC" border="0
2-E3-A6-CC5-B1-A0-4-FD7-912-D-FE3-E395-FADC9" border="0
71-CFEB1-B-B541-4507-9-BD1-E4-E52923-F2-A4" border="0
FEB06-F37-01-DF-44-C9-84-AC-C4-CD46796-FAB" border="0
E2-BD3-DBB-D9-B4-4043-B372-3-C2-AB34-D1-E4-C" border="0
