April 18, 2024, 08:51:36 AM *
Pages: 1 ... 14 15 [16] 17 18 ... 28
Author Topic: Archie's Volksrod  (Read 90064 times)
« Reply #225 on: April 20, 2019, 09:35:07 AM »
It’s sat on the lowest setting currently on the adjusters so needs to come up a bit.
Body is channelled over the pan too so the floors not at the height luckily. Bonnet might take a bit of a beating though I guess
« Reply #226 on: April 20, 2019, 10:12:52 AM »
Looking forward to seeing it on the streets! Smiley
« Reply #227 on: August 13, 2019, 07:53:05 PM »
BF4907-C4-AE3-B-4-FAB-BFF4-F63986954-A2-F" border="0
It’s not so low it can’t get on a trailer.
It’s now up at my works workshop, so hopefully things might move on a bit.
« Reply #228 on: August 13, 2019, 08:09:06 PM »
Well, that's kinda on the streets Smiley
Still really struggling with motivation for mine. Good to see someone making progress.
« Reply #229 on: August 17, 2019, 07:55:09 AM »
Crossmembers propped in and offside one starting to be welded in. From there I can start to build up a tub / bulkhead
06486-AAB-78-CE-4-FE3-82-F8-4-ABC15802145" border="0
BDB3-EFE9-0-BC9-4136-A775-4-A373931-FE2-A" border="0
« Reply #230 on: August 19, 2019, 05:33:34 PM »
Started tacking in the bent up piece. Not particularly straight due to all the shapes on a beetle and real thin old metal. Also cut out an old repair to redo. Once that’s done it should be onto the other side to do the same again.
9-FA1-B0-D3-359-C-4-F95-A30-E-281-A9-DF90039" border="0
7-F3-A61-B1-174-D-4-CB9-85-DC-9529-E7-FE1-FE3" border="0
C5-F46952-0-F9-C-4-C47-B1-A8-11841-F40-B517" border="0
« Reply #231 on: August 19, 2019, 08:41:21 PM »
Lookin' good mate.
« Reply #232 on: August 20, 2019, 08:42:39 PM »
Cut out the old quarter repair I did as it was pretty mangled. Then treated the rust on the frame behind it with converter. I also went over the bonnet and other patches to just make it not look so ropey
38-CFCE0-D-4-C38-474-E-9-B7-C-5727-AE7-B3147" border="0
5-ABDCD48-E928-4267-89-CD-37-BEDE61-AD1-B" border="0
7-A6-B8-A62-7-EEB-4-F3-C-A7-EC-A78-C7280087-A" border="0
6795890-C-56-D1-4-E8-E-BE93-CDD158-F426-F9" border="0
<a target='_blank' href='https://freeonlinedice.com/'>ten sided dice[/url]
« Reply #233 on: August 21, 2019, 06:00:44 AM »
Is this how low you want to run this on the street?  Can you not fit airbags?
« Reply #234 on: August 21, 2019, 06:42:57 PM »
Ride heights not been decided yet.
Rear quarter shaped and tacked in
0-CD90484-00-EA-4-BDF-B2-CB-69-ECACDDD77-C" border="0
1-E1-C13-CD-5-E68-4877-9-D67-06-EBCE5-C396-C" border="0
<a target='_blank' href='https://imgbb.com/'>upload images without account[/url]
« Reply #235 on: September 10, 2019, 01:56:30 PM »
Haven't updated on here, but have been tinkering away. will put some photos up at some point but they're pretty boring
Started on the other side of this and one big problem was the heater channel. We'd already cut and welded it once, but it was still too long and sitting too far forward. So braced up the door gap, cut the thing out, cut the head off it, cut 10mm out of the length and rewelded it and bolted back in. Now sits where it is supposed to.
The body is sitting on the wonk a bit and it looks like if I take another 2cm out of the C post it will drop down and sit just a bit nicer.
On the other rear quarter it's pretty much welded in and i put a piece in the inside to come across from the channel to the quarter and it has just stiffened all up.
But yeah this is a nice exciting part as it's back to moving forward again
« Reply #236 on: September 10, 2019, 03:35:27 PM »
Great to see people building stuff here again Smiley
I really like the unchopped & lowered look.
« Reply #237 on: September 10, 2019, 04:30:32 PM »
it looks great from the side, but from the front - just too much forehead going on
« Reply #238 on: September 11, 2019, 06:49:53 AM »
Sounds like me?🤣
« Reply #239 on: September 11, 2019, 08:03:20 AM »
