May 18, 2026, 01:24:57 PM *
Author Topic: kitten to be reborn a zzr11 kitten  (Read 7012 times)
madkitten
« on: May 03, 2011, 08:40:57 PM »
hi all the title speaks for its self , yes i got kitten and its going bike power .
problem is i know a bit about robins alot about cars and bikes but nothing about kittens and even less about converting them. anyhows i know what i wanting to do with it but don't know how hard or maybe even near damm impossible some things may be .  bike engine fitting seems fairly easy to me . going to make a subframe similar to the bike frame to use engine mount bolts and will brace along both chassis rails to help chassis roll. wanting to make wide wheel arches and skirts . make new bumpers ect bonnet vents .
running gear i will worry about it bit by bit . iffy bit is axles brakes and which am sorted for rear axle and discs. but what about discs for the front .Huh not a clue lol.
also wheels . want wider and will need bigger to take disc conversion but what size will fit the kitten without altering original suspension and bits. Huh   does anybody on mm motors know a bit about kittens or possably even about pimping them!!! any help is a step in the right direction . thanks
Plasticpig
« Reply #1 on: May 04, 2011, 01:29:41 PM »
 Not knowing a lot about modern jap crap japanese bikes, I take the zzr 1100 is chain driven?
If so, a lot of bike-engined kit cars use jap inline fours mounted inline. You can buy adaptors for the propshaft which slide over the splines of the output shaft where the normal sprocket fits. That way you can fit the zz lump in the same direction as the piggy engine, and not have to worry about an extra subframe.
Al
« Reply #2 on: May 04, 2011, 09:03:05 PM »
this was advertisedon another forum but might be worth alook or phone call it has everything you need for the lump http://locostbuilders.co.uk/forum/34/viewthread.php?tid=154710 unless you have one
al
madkitten
« Reply #3 on: May 04, 2011, 09:12:20 PM »
hi yes that's right . the easy bit is fitting the engine . the prop will bolt straight onto the front sprocket prop adapter. all it is a front sprocket with a flat piece of metal welded to it and turned true on a lathe and holed . easy as that . got all my diagrams and measurements for the engine fit .( probably end up throwing them in the bin and making it up as i go along lol but i want to try to be organised this time . not like my last 10 projects lmao. but really need to know about wheel sizes i can use with using disc brake conversion and remembering that wheels got to clear standard suspension set up
Al
« Reply #4 on: May 04, 2011, 09:14:10 PM »
http://www.sprocket-adaptors.co.uk/Page%202%20(Flange%20Dimensions).html
try here for the adaptor
al
bitzman5
« Reply #5 on: May 04, 2011, 09:19:17 PM »
HI Yes the zzr1100 is chain drive there is a yamaha  engine that runs a conversion unit from short chain drive to shaft but for the life of cant remember which yamaha
madkitten
« Reply #6 on: May 04, 2011, 09:22:56 PM »
thanking you very much . thats saved me ages doing net searches. that is  exactly was what i be needing .  Smiley
madkitten
« Reply #7 on: May 04, 2011, 09:26:25 PM »
dont really fancy the whole chain thing . gets a bit loose get a bit tight  and bam they snap! have enough problems even remembering to oil my bike chain lol
Al
« Reply #8 on: May 04, 2011, 10:01:47 PM »
is it not the xs1100 bevel box that is normally used iv used  one a long time ago for on a fj1200
al
« Reply #9 on: May 04, 2011, 10:02:06 PM »
Yamaha XS750, 850 & 1100s used a "bevel box" -a seperate unit which turns the drive from the gearbox through 90 degrees to hook up with the shaft that drives the back wheel. When you take it off the engine, you have a unit with a splined shaft on one end that will accept a sprocket, & a flange on the other to bolt to a propshaft. Perfect for chain/shaft conversions. Chris Ireland, ("Desperate Dan"), used them extensively when he was trike building.
« Last Edit: May 05, 2011, 07:26:24 AM by Manky Monkey » Logged
bitzman5
« Reply #10 on: May 04, 2011, 11:07:31 PM »
Andy to the rescue again knew it was a yamaha that had the box
« Reply #11 on: May 05, 2011, 03:47:00 PM »
If you wanted to be really clever get a belt drive made up instead of chain and sprockets  Wink Wink Wink Wink
madkitten
« Reply #12 on: May 08, 2011, 05:43:20 PM »
yer but missed a point a bit . im not using a chain . chains r st**. no chain . a sprocket adapter goes on final drive splines like a normal front sprocket would . instead of teath its got 4 holes which you bolt the prop onto   no chain . well cool better than any chain or belt . but nice idea
« Reply #13 on: May 08, 2011, 10:15:17 PM »
     what about reverse Roll Eyes Roll Eyes
madkitten
« Reply #14 on: May 09, 2011, 07:15:40 PM »
flintstone car lol . get out and push Huh dont know maybe some sort of battery powered motor
