May 19, 2026, 01:41:01 AM *
Pages: 1 2 [3]
Author Topic: rover distributor  (Read 17812 times)
« Reply #30 on: April 12, 2011, 03:30:42 PM »
Well if that's what you wanna do.....
The Black/White wire from the dizzy goes to the coil -
The Red wire to the coil +
12V feed into the coil +
NO NO NO that's not what I wanna do. ITS whats been said that can be done.dizzy with electronic ignitions don't need a ballast resister
« Reply #31 on: April 12, 2011, 03:54:46 PM »
From tbone
Reply from tt
tbone that's how we wired it up on sunday.just luck i think me and Brock checked it and that's what we came up with.  and is still wired like that
From tbone
you cannot run that dizzy correctly without the 6 wire resistor. Putting a direct 12v feed to the coil will saturate it magnetically, as well as overheat it, both these will cause a poor spark / misfire and eventually the coil will burn out.
The system is designed to be used with that box!
Reply from tt
and these are some of the symptoms we had that you have listed above
« Reply #32 on: April 12, 2011, 04:50:40 PM »
Erm, would this help?   Grin
Spent all day thinking surely I wouldn't be daft enough to throw it away would I? Scoured the barn we store Taz's Dodge in when I got home & sure enough, there it was. So hopefully, crisis averted.
-so, can we run a standard 12 volt coil with this? Got one fitted on the Pop at the moment. Or do I need to use the rusty old one that came off the engine when I bought it? No markings on it & no guarantee it's a 9 volt one.
We'd love to get the Pop to WheelsDay at Rushmoor Arena, but got no way of getting it there yet. Anyone going -with a trailer?
« Reply #33 on: April 12, 2011, 05:07:53 PM »
that's great Andy.take them to the work shop next time you go.let me know what days/eve you will be there and i will try and come over to have a look and fit them and set up the timing.
« Last Edit: April 12, 2011, 05:11:00 PM by terry t » Logged
« Reply #34 on: April 12, 2011, 05:15:23 PM »
[/quote]
I fully agree with that statement.
What you have however, is an early transitorised occillating pickup. This was one of the first electronic systems developed and unlike later versions, it needs the control that the resistor box gives.
Appears we had a slight mis-understanding, I was reading the thread as wanting to dispose of the box, not that it had been lost, I`ll go back to rigging my lobster creels  Grin
« Last Edit: April 12, 2011, 05:23:06 PM by tbone » Logged
« Reply #35 on: April 12, 2011, 05:23:36 PM »
Appears we had a slight mis-understanding, I was reading the thread as wanting to dispose of the box, not that it had been lost  Grin
Then found again.thanks tbone. do you know what coil would have been used  Roll Eyes
« Reply #36 on: April 12, 2011, 06:19:26 PM »
I would guess that Andy`s rusty one has C22 stamped on the bottom  Shocked
I`d go for a coil suitable for electronic ignition, all the V8 non points systems should use the same coil. (these have a primary resistance of 1.0 ohm).
And thats the last time i use that R word  Grin Grin
toad
« Reply #37 on: April 12, 2011, 06:23:27 PM »
right let me clarify this a bit! The ballast resistor is only fitted to aid starting. if you look at the wiring diagram for a pre 1985 rover v8 dizzy you,ll see its wired to the aux tag on the starter solenoid, Thats to give a constant 12v,s whilst starting, and not cause a voltage drop at the coil. if the power feed is wired direct to a permanent fused power supply to the battery and not a spliced supply as in most cars then the coil and distributor will perform perfectly.
I did my apprenticeship at dutton forshaw,s 3yrs on rovers and jaguars Wink
« Reply #38 on: April 12, 2011, 07:37:36 PM »
The ballast resitor is fitted to reduce voltage to the coil.
Electrical componants are made to operate at specific values, you cannot 25% more voltage through without adverse affects.
 Smiley
toad
« Reply #39 on: April 12, 2011, 07:55:57 PM »
Im no making any more comments on the subject Kiss
« Reply #40 on: April 12, 2011, 08:06:26 PM »
 Kiss
« Reply #41 on: April 12, 2011, 10:38:53 PM »
Did I say "one final time......", ho hum! but of course your right Mr.T, run above the rated voltage, and you won't run for long!! Morrag
toad
« Reply #42 on: April 13, 2011, 07:16:23 AM »
this will be my last post on this honest Grin im donating a suitable distributor and will fit it saturday afternoon and set it up for the last time!!! Grin
« Reply #43 on: April 13, 2011, 02:39:51 PM »
I just happen to have a. 8 cylinder Scintilla Vertex magneto, off a WW1 fighter, now that would be........ no I haven't, honest!!!!
Pages: 1 2 [3]
