« on: April 06, 2011, 07:58:12 PM » |
Next question!!  I've got a bank of Mikuni carbs that have what looks like two fuel inlets, one at the bottom of the bank (which was connected to the fuel tap on the tank), and another at the top of the bank that isn't connected to anything!! Should it be??
Cabman77
« Reply #1 on: April 06, 2011, 08:07:46 PM » |
breather pipe
« Reply #2 on: April 06, 2011, 08:27:34 PM » |
Really?  Okay! Thanks buddy!!
Cabman77
« Reply #3 on: April 06, 2011, 08:44:08 PM » |
I believe it should double back to a pipe on the tank. Seen a lot of jap bikes like that.
« Reply #4 on: April 07, 2011, 11:50:47 AM » |
Vacuum pipe for vacuum tap on tank?
"It's time to raise the Finger, That middle digit takes your point and drives it home"
« Reply #5 on: April 07, 2011, 04:50:33 PM » |
Nope, found that one already, and comes from the outlet rubber, not the top of the bank of carbs! Found a pipe outlet/inlet on the bottom of the tank that I reckon should be connected to it!!
Cabman77
« Reply #6 on: April 07, 2011, 07:41:31 PM » |
toad
« Reply #7 on: April 07, 2011, 08:19:21 PM » |
Clive. be careful that outlet could be the drain pipe for the filler cap. what bike is it???
« Reply #8 on: April 08, 2011, 12:37:09 PM » |
A bandit buddy!
toad
« Reply #9 on: April 08, 2011, 05:23:32 PM » |
Next question!!  I've got a bank of Mikuni carbs that have what looks like two fuel inlets, one at the bottom of the bank (which was connected to the fuel tap on the tank), and another at the top of the bank that isn't connected to anything!! Should it be?? If it comes out on a black plastic t piece its a breather mate.
« Reply #10 on: April 08, 2011, 05:24:48 PM » |
It does, so it is!!  Should it be connected to anything?
toad
« Reply #11 on: April 08, 2011, 05:31:01 PM » |
no mate it just vents into the air. im breaking a 1200 bandit at the moment alot of the parts are generic if you need anything
« Reply #12 on: April 08, 2011, 05:35:34 PM » |
Thanks buddy! Will let you know, but this one isn't a complete dog..............possibly
retro900
I Love The Blues They Tell My Story
« Reply #13 on: May 29, 2011, 02:32:56 PM » |
Always worth remembering that if the bike is coolant cooled that could be plumbed into the carbs as well, the ZRX and many others are like this. They use the warm coolant to stop the carb icing up.
