December 23, 2025, 10:16:31 AM *
Pages: 1 ... 25 26 [27] 28 29 ... 32
Author Topic: What's in the workshop today Loony?  (Read 165390 times)
« Reply #390 on: August 05, 2013, 11:19:04 PM »
It's really about time Tom's XS650 had it's own thread. After a bit of a lapse, it's now being worked on again, with Tom spending a few afternoons at Loon's workshop recently. He bought a pair of 1/8"NPT brass fuel taps from the States, plus 2 threaded inserts. This evening I nipped over to my brother Brock's workshop in Wiltshire & pestered him to TIG weld them in place & blank off the original tap hole under the tank. A lot of work, as the tank had previously been repaired with braze, which doesn't react well to TIG welding, but nicely done.
The wonderful thing about TIGers, is I'm related to one.
http://www.fieldcraftfabrication.co.uk/
« Reply #391 on: August 05, 2013, 11:19:51 PM »
« Reply #392 on: August 06, 2013, 08:05:42 AM »
Think I'm beginning to see a trend here.  Smiley
Nice work as always Brock.
hornet6
« Reply #393 on: August 06, 2013, 12:53:51 PM »
Nice work there......I tig weld conveyors and large wash tanks at work...and then come home and tig weld bits and pieces to flog on evilbay in what spare time I have left Grin Grin
no projects ever finished
« Reply #394 on: August 06, 2013, 10:16:59 PM »
There's definitely an art to it. I've got a 150 MIG, but haven't used it for 4 or 5 years at least -I seriously think I've forgotten how. A properly run bead of TIG weld is a thing of beauty.
Tom's tank tried in place on the frame. He's very happy with the taps & asked me to convey his thanks Mr Brock. Tom's going for a slightly steampunk/industrial kinda look, mixed with a bit of 60s inspired craziness, so the sticky outyiness of the big brass taps is just what he was looking for.
« Reply #395 on: August 06, 2013, 10:17:37 PM »
On the right of the tank are 2 right angled fittings screwed into threaded bungs, welded into the tank. There'll be a short length of coloured plastic fuel line between them as a fuel level sight glass.
« Last Edit: August 06, 2013, 10:19:34 PM by Manky Monkey » Logged
hornet6
« Reply #396 on: August 07, 2013, 05:57:31 PM »
yep.....made some of those with stainless threaded elbows,and brass tail pipes. Just out of interest...would that pass the mot test with the fuel gauge on the outside of the tank....or do you just blank them off on the day of the test?
« Reply #397 on: August 07, 2013, 07:57:55 PM »
A good question, & one I've asked too. Not sure. Anyone know?
blair
it looks bigger in water ! !
« Reply #398 on: August 08, 2013, 08:50:34 AM »
dont know about the mot but is he sure those taps will pass the msva ? , i know the filler cap has a max height and thats to save your nuts if you have a  head on and slide up the tank , dread to think what they would do to you.
also dont think they look right , if they curved out of the tank downwards following the lines of the backbone that maybe , but its not my bike  Grin
« Last Edit: August 08, 2013, 08:52:08 AM by blair » Logged
« Reply #399 on: August 08, 2013, 08:15:00 PM »
Or mine. Personal taste & all that. Curved would be nice.
« Reply #400 on: August 08, 2013, 08:19:28 PM »
Chris's split screen Moggy Minor. He's still working on this most afternoons. After a bit of a disaster with the 4 speed manual gearbox, (he's fitting a Rover V8 engine), while attempting to change the oil seals in it, he's now given up trying to shovel all the cogs back into it & bought a 5 speed instead. The Orca the killer whale paintjob was just an experiment, though I quite like it.
« Reply #401 on: August 08, 2013, 09:08:57 PM »
I love this Moggy. Cool
« Reply #402 on: August 09, 2013, 07:18:58 AM »
Me too.
 Chris has worked hard on this. Well he makes a lot of noise with the angle grinder Wink
The 4 speed is supposedly stronger but the 5 is much nicer and more usable, so a wise decision. Is he going to change the oil seals ?
« Reply #403 on: August 09, 2013, 07:06:32 PM »
I once owned the only Moggy in - probably the world! - that engaged first gear and reverse at the same time - and 2nd and reverse, and 3rd etc etc etc.................
« Reply #404 on: August 09, 2013, 07:15:48 PM »
Yeah, probably best to leave this gearbox well alone then!
