April 06, 2026, 03:57:56 AM *
Author Topic: Nitrogen filled tyres?  (Read 4899 times)
« on: March 07, 2011, 07:19:43 PM »
I was perusing the North Hants Tyres website & came across this. Fill your tyres with Nitrogen for 2 quid per tyre. That's a new one on me. Anyone tried it?
http://www.northhantstyres.com/nitrogen.htm
« Last Edit: March 07, 2011, 11:46:32 PM by Manky Monkey » Logged
« Reply #1 on: March 07, 2011, 07:46:15 PM »
I quote from another forum
"Filling Nitrogen in tyres has NO apparent advantage over normal compressed air! It's a marketing gimmick, ignore it."
But I will look in to this a bit more before I agree or disagree with this statement.
thebigdogsix
« Reply #2 on: March 07, 2011, 08:05:52 PM »
What about filling your tires with helium making your car lighter  Grin Wink
« Reply #3 on: March 07, 2011, 08:34:50 PM »
It is supposed to keep tyre pressures contant as it isn't affected by the temperature changes we get in the UK on road tyres. Never done it in a vehicle but we used to fill the tyres on a coating plant drying drum with nitrogen due to the heat and it worked on that.
Always been a bit suspect for cars and bikes and stuff especially as air is generally free Wink
« Reply #4 on: March 07, 2011, 10:39:21 PM »
Many years ago I filled a front tyre with straw, to replace a shredded tube, to get me home, but I wouldn't recomend it! does nowt for the handling........
Mr_G
« Reply #5 on: March 07, 2011, 10:51:01 PM »
So is nitrogen if you know where to get it from xD. I have heard about filling your tyres with nitrogen before, Can't quite remember where though.
« Reply #6 on: March 07, 2011, 11:53:10 PM »
The blurb on N.H Tyres' site says Nitrogen slows wear to tyre rubber & keeps tyre pressures constant etc -is it really worth worrying about?!
« Reply #7 on: March 08, 2011, 05:54:17 AM »
Maybe if you're someone like McClaren......... Wink
(08/03/11 following Trev's posting below -  maybe that should be "McLaren"? Show how impressed I am with F1 !!
« Last Edit: March 08, 2011, 05:48:33 PM by Tony oily bike » Logged
trev
« Reply #8 on: March 08, 2011, 01:26:07 PM »
don,t they put it in the massive dumpers in quarries.
« Reply #9 on: March 08, 2011, 01:59:12 PM »
Think we may have ended up doing that just before I got made redundant, was some gas/air mix but can't remember what.
It only reduces tyre wear by keeping constant pressure from what I have seen. If you are one of those people who regularly check and adjust pressures there is less advantage. I know a few raved over it on the car forum I used to belong to but I have never used it outside of a work environment. Thinks its same as owt else, ya pays ya money and tales your chance Smiley
« Reply #10 on: March 08, 2011, 08:19:43 PM »
Somebody tell me if i`m wrong (I`m sure you all will) my murky memory of chemistry lessons tells me that when Nitrogen is heated it actually cools and liquifies, thus cooling the tyre which then heats up a bit again and so on and so on. This could be the reason for better tyre wear claims. Does that sound right. I will happily stand in the corner with the dunces cap on if I`m wrong.
