May 17, 2026, 04:16:57 AM *
Pages: 1 [2]
Author Topic: DOC! HELP PLEASE.  (Read 9297 times)
« Reply #15 on: March 11, 2011, 07:57:16 PM »
I had considered this, not with that engine, but one of the small ones.
It would mean rigging up a longer exhaust to exit through the back wall of the shed, but thats do-able.
There is also a countershaft shaft on ebay at the moment with a floating pulley, hmmm the more i think about it......
« Reply #16 on: March 14, 2011, 06:24:13 PM »
So, look what was waiting for me when i got home.
« Reply #17 on: March 14, 2011, 06:33:58 PM »
Kool! Grin
« Reply #18 on: July 20, 2011, 07:22:11 PM »
Where does the time go?!
4 months ago it was when i got that jackshaft, finaly got round to doing something with it.
Tis now mounted behind the lathe and working, sort of....the arm that i made to carry the adjusting bolt was fine to start with, after running the lathe through its various speeds, i find the arm bends forward when the belt is tightened.
The arm is welded onto an L shaped bracket that is bolted through the bench, i have 2 options open to me, firstly, turn the arm around so the leverage is acting against itself, or add a second L shaped bracket behind the arm.........
« Reply #19 on: July 21, 2011, 06:19:51 AM »
Photo's please TB.
« Reply #20 on: July 21, 2011, 05:30:32 PM »
Sure  Grin
The shaft and motor are mounted on a hinged wooden plinth.
« Reply #21 on: July 21, 2011, 05:36:05 PM »
This is the arm that holds the long adjuster bolt.
I have now turned it through 180 deg, so that it pulls the bracket back rather than together.
I still may have to `beef` it up but its better than it was.
« Reply #22 on: July 25, 2011, 12:02:48 PM »
All looks ok but you will need to strengthen everything and I would loose the wood and just use steel I have a similar set up but much stronger.
I also have my lathe mounted on a steel bench which helps alot I just weld bits straight to the table.
« Reply #23 on: July 25, 2011, 01:10:12 PM »
Strangely enough.....Thats what i sort of did this morning  Grin
The arm is now welded to the frame of the bench behind the lathe. I`m still running wooden motor/shaft mounts as i thought this may help with vibration issues. I have some 3mm plate so will give that a go.
Pages: 1 [2]
