dobber
« Reply #255 on: November 13, 2011, 02:40:08 AM » |
was told a while ago by mm i think that the brake push rod between pedal and master may need a stiffner, def does.
« Last Edit: November 13, 2011, 12:34:05 PM by dobber »
no rush fella, take all the time you need, can i have it in 20 Min's?
dobber
« Reply #256 on: November 13, 2011, 02:43:05 AM » |
got calipers on and stainleess flexies, quick bleed and instant pedal. left it pressured up with aid of a stick. see what its like in morning...
dobber
« Reply #257 on: November 13, 2011, 02:45:16 AM » |
just need to smarten route up of the flexies
dobber
« Reply #258 on: November 13, 2011, 02:49:55 AM » |
tried the cable tie way to tension the spring in the caliper... turned out the better way was to put a socket over the spring case and clamp it whilst using 2 butchered screwdivers as a makeshift pair of circlip pliers
andyrennison
« Reply #259 on: November 13, 2011, 03:12:25 AM » |
Those calipers look tasty
dobber
« Reply #260 on: November 13, 2011, 10:10:43 AM » |
cheers andy, often thought about putting laquer over red oxide, like the matt effect.
dobber
« Reply #261 on: November 13, 2011, 12:45:18 PM » |
need a smarter way of clipping cables up.
« Reply #262 on: November 13, 2011, 12:53:51 PM » |
Mousy Boy :-) AKA Mick
dobber
« Reply #263 on: November 14, 2011, 09:32:41 PM » |
new extended lenght, been that long i cant tell now.. the trailer bed its sat on is 10ft as a guide..
« Last Edit: November 14, 2011, 09:34:44 PM by dobber »
« Reply #264 on: November 14, 2011, 09:40:54 PM » |
it looking good dobber. any chance of turning the lights on when you take any more photos.  .have you tried the brakes out with those s/s brake lines
dobber
« Reply #265 on: November 14, 2011, 09:56:54 PM » |
put new battery's in camera terry, when flash's on now the whole screens blank white. don't know what to do with it. brakes work but rods too long and flexing, got some thin apx 5mm stainless rod I'm going to replace the threaded bar with, running it through some tight fitting fuel pipe which in turn will go through stainless tube fixed to the frame. will try maybe fitting a grease nipple on it so the rubber fuel pipe slides easy in the tube.
« Last Edit: November 14, 2011, 10:05:06 PM by dobber »
dobber
« Reply #266 on: November 20, 2011, 01:54:41 PM » |
took engine out today for a clean up and some new basic gaskets
dobber
« Reply #267 on: November 20, 2011, 02:10:18 PM » |
cleaned with wire brush in grinder and degreased.
dobber
« Reply #268 on: November 20, 2011, 02:13:16 PM » |
wanted to get it oil tight before committing too much cos not sure how it runs
Al
« Reply #269 on: November 20, 2011, 02:18:58 PM » |
hi dobber that is looking good on some of the reliant axles have clips that blend in to axle dont know if they would do for the braided but might be worth a try iv got two if you want them al
