April 06, 2026, 12:30:19 AM *
Pages: 1 ... 12 13 [14] 15 16 ... 43
Author Topic: dobbers trike  (Read 248471 times)
dobber
« Reply #195 on: October 15, 2011, 05:14:28 PM »
set back end up , tacked together,axle sat where it needs to be. need to lengthen prop now that i had it shortened, [[[ measure once, cut twice]]] easy to mount some bumper set up to the ends now. perhaps 2 inch tube with dome ends and small lights set into it.
        can i have it in 20 Min's?
dobber
« Reply #196 on: October 26, 2011, 05:44:54 PM »
shaped a piece to go from out side frame one side to other, following same shape as bit forward of it. used some 2 inch ally box, clamps and bits of timber to spot anywhere that distorts
« Last Edit: October 26, 2011, 05:55:26 PM by dobber » Logged
dobber
« Reply #197 on: October 26, 2011, 05:52:45 PM »
then braced it back to seat frame thus creating a box effect to get rigidity. done it just high enough to get the axle out with discs off should i need to. going to mount a bandit 1200 silencer side ways off it so it looks like its there for a reason.
   lad who works at steel place across the way dropped me 7ft of 2inch stainless tube off which was to be for a bumper but not strong enough. will do to join to manifold somehow and make a one piece exhaust  back to bandit can.
dobber
« Reply #198 on: October 26, 2011, 06:01:33 PM »
going off the idea of a tube bumper. looking for something different. perhaps utalizing something pre made..
   anyone any ideas
« Last Edit: October 26, 2011, 06:06:20 PM by dobber » Logged
zakboy
« Reply #199 on: October 26, 2011, 06:12:04 PM »
you have been busy dobber  Wink good man
dobber
« Reply #200 on: October 26, 2011, 06:25:42 PM »
once i get the steel n bender zakboy it don't take long to do.
   whats your opinion on the strength, the upward pressure as the wheel gets pushed up putting the pressure on the upright bit of the furthest back : arch : should then transfer down the two pieces to the next  : arch shape : [the box effect]  but the cross pieces are apx 8 inch inward.. you think it will still be strong enough. feel really solid just tacked up...
zakboy
« Reply #201 on: October 26, 2011, 06:37:35 PM »
It looks fine to me dobber, i do tend to go over the top some times with overkill running your tyres at low pressure will help a lot in absorbing shock from the pot holes and uneven road surfaces beeing a bit more forgiving on the frame.... what length are we at with the trike
dobber
« Reply #202 on: October 26, 2011, 06:44:49 PM »
7 ft wheel center to wheel center and apx 9 ft from front of front tyre to the ends where bumper will end.  because its so low it makes it look longer. how much longer do the conversion ones you do end up?
zakboy
« Reply #203 on: October 26, 2011, 07:00:17 PM »
Thats suprising it looks longer,thats a good length still a short trike, the xv bolt on is a little under 8 feet
RODeo
« Reply #204 on: October 27, 2011, 07:44:10 PM »
Looking good there Dobber! Cool
  Mine is 2.5 metres overall length.
dobber
« Reply #205 on: October 30, 2011, 07:56:54 PM »
,mate, darth vader came with his mig and welded up everything i tacked up
« Last Edit: October 30, 2011, 08:10:26 PM by dobber » Logged
dobber
« Reply #206 on: October 30, 2011, 08:05:19 PM »
made an allmighty  blunder. purposely made the box bit at the back tall enough to slide the axle out underneath in case of repair etc, stupidly never thought the diff couldn't come side ways enough to drop the end of the axle thru the middle of the frame. had to cut a section of tube out.  will have to mess with it so the section can be unbolted for axle removal. . bit like some bikes that have a section of the frame which unbolts to get the lump out.
dobber
« Reply #207 on: October 30, 2011, 08:07:46 PM »
gave the axle a clean, primer then gloss black.
« Reply #208 on: October 30, 2011, 08:17:42 PM »
D'oh! Glad I'm not the only one who makes cock-ups, creates design flaws, like that.
dobber
« Reply #209 on: November 02, 2011, 10:16:55 PM »
got the axle back on and bolted the brake bits, arch and wheel on one side.   seem to have spent more time studying this rear than i do with the local lasses ones.
