April 06, 2026, 04:38:20 PM *
Pages: 1 ... 33 34 [35] 36 37 ... 43
Author Topic: dobbers trike  (Read 248696 times)
dobber
« Reply #510 on: June 14, 2013, 09:08:58 AM »
not much in the way of bits to fit in the box. mounted bits on a bid of grp so i can lift the lot out if necessary
        can i have it in 20 Min's?
« Reply #511 on: June 14, 2013, 09:10:38 AM »
Whey hey, Dobbers back!
« Reply #512 on: June 14, 2013, 09:12:23 AM »
very neat.
dobber
« Reply #513 on: June 14, 2013, 09:14:42 AM »
hi andy, does seem like forever. had a look for my thread, was dec 10 when started it. 90% was done straight away
dobber
« Reply #514 on: June 14, 2013, 09:16:26 AM »
drilled a hole to give a shape then slotted it and powerfiled it to take a gromet for first of wires
dobber
« Reply #515 on: June 14, 2013, 09:17:47 AM »
box lid will slide over when slotted
dobber
« Reply #516 on: June 14, 2013, 09:19:19 AM »
nibbled away with cut off disc then end of powerfile again
dobber
« Reply #517 on: June 14, 2013, 09:20:30 AM »
two mins on buffer to polish up
dobber
« Reply #518 on: June 14, 2013, 09:22:58 AM »
will try get maximum wires thru minimum holes to keep it neat
dobber
« Reply #519 on: June 14, 2013, 09:16:55 PM »
needed a earth for the solenoid in the lecci box so drilled n tapped so not having to get under it to put a nut on and off if need electrics out
dobber
« Reply #520 on: June 14, 2013, 09:19:08 PM »
put the leci bits in and shortened the earth and live to make it neater. bolted the stainless plate down with a couple of 6 mm allen stainless bolts.. the earth to the chassis is on the bolt that holds a reliant hand brake plate which is a footrest for the pillian and matches the other side which is the actual handbrake and a foot rest
« Last Edit: June 14, 2013, 09:22:55 PM by dobber » Logged
« Reply #521 on: June 14, 2013, 09:23:44 PM »
That's tidy. Wish I understood electrickery.
dobber
« Reply #522 on: June 14, 2013, 09:24:42 PM »
footrests back on
dobber
« Reply #523 on: June 14, 2013, 09:29:16 PM »
view looking down without seats on and from side.. made a boll@>:s.  cant lift the stainless lid off without moving the handbrake bracket. never saw it coming... can live with it.
dobber
« Reply #524 on: June 14, 2013, 09:34:36 PM »
cant really see electric and battery bits from the side and back.
bolted the horn on and wired, need to sort some sort of console up front now for the warning lights
