April 06, 2026, 10:19:00 AM *
Pages: 1 ... 26 27 [28] 29 30 ... 43
Author Topic: dobbers trike  (Read 248609 times)
digger06
« Reply #405 on: February 19, 2012, 09:06:05 PM »
i see, i got told they were to prevent too much movement and stop the rubbers shearing, i never had them, when mine went, i replaced em with something bigger off something else
« Reply #406 on: February 19, 2012, 09:09:31 PM »
Yep , Landrover mounts work well  Grin Grin
dobber
« Reply #407 on: February 19, 2012, 09:28:21 PM »
checked the rod for that  fifer. drilled out the hole so not tight, power filed the edges and put a loose spacer so wingnut wasnt jaming.  not sure i can push the arm by hand. really stiff.
 going for solid mount anyhow so would like to suss it first.
        can i have it in 20 Min's?
dobber
« Reply #408 on: March 16, 2012, 08:07:08 PM »
right,,, back on with this after it started pouring oil out. thought it was the rear oil seal but when i replaced it sussed it was the sump. changed the front seal as that was def leaking. took the sump off, cleaned it up and knocked the bolt holes down a bit which looked raised. cleaned the gasket with petrol and the block then put gasket seal on as well for a belt n braces job.
dobber
« Reply #409 on: March 16, 2012, 08:09:18 PM »
used the crane thing i have which runs across the depot on beam monkeys to put the engine and box back in. didnt think it would work in the past but made it proper easy.
« Last Edit: March 16, 2012, 08:18:06 PM by dobber » Logged
dobber
« Reply #410 on: March 16, 2012, 08:15:30 PM »
when the steel guy asked to borrow the forks i got into him for some steel to change the mounts to solid and he gave me these to try.  very solid nylon bushes with a 8mm thread down the center. put two together ,cut one down with the chop saw  so the two were  the same length as the original mounts.quite handy if you need to lift or lower the engine height.. they have a coller type thing at one end.
dobber
« Reply #411 on: March 16, 2012, 08:20:47 PM »
all back in and mostly built up. couldnt put oil in in case it leaked again and spoilt my night out... need a break with it to get interested again.
« Reply #412 on: March 16, 2012, 10:53:16 PM »
Looking super clean now Dobber.
one arm bandit
« Reply #413 on: March 17, 2012, 10:44:41 AM »
what colour scheme are you going for on the frame and tins??
dobber
« Reply #414 on: March 17, 2012, 12:29:08 PM »
hi bandit,  theres a photo of a bike i did on page two of this thread which is what i was gonna do the trike in. not sure now, just want to get it drivable. may get a lot of white powder coat on the engine tho.
dobber
« Reply #415 on: March 17, 2012, 09:18:59 PM »
.............IT RUNS..................
 15 month or so down the line i finaly fired it up. sounds ok. cured the leaking sump and rear seal but the front ones still leaking with the new seal in. had the pipes to and from the fuel pump the wrong way round, was trying to pump fuel out of the carb.
 started to mount the r6 radiator , not a lot of room.
 any one know what the crack is with the pipes. got the main in and out but whats the other smaller one for and the two little ones. the overflow one is tucked under the cap
« Reply #416 on: March 17, 2012, 10:59:28 PM »
Great Stuff  Smiley
I take it that you fitted the timing pulley before tightening up the timing cover bolts so as to centralize the cover around the pulley . Smiley
If Yes , Remove the timing pulley and have a look for wear where the seal rubs on .
If worn , you might need to fit a Speedi Sleeve or get another pulley in good condition .
dobber
« Reply #417 on: March 17, 2012, 11:15:51 PM »
put the pully on first then nipped the bolts up.
  saw the sleeve thing. how do you measure to fit or can you just say its for a reliant  pully.
« Reply #418 on: March 17, 2012, 11:44:38 PM »
I think the pulley journal measures around 35mm diameter
If So then Part Number CR 99139 , which fits from 34.92mm to 35.08mm , should do the trick
Info at
http://www.skf.com/portal/skf/home/products?maincatalogue=1&lang=en&newlink=4_5_4
Suppliers info at
https://sites.google.com/site/fifersrelianthintsandtips/specialist-parts-suppliers/directory-of-specialist-part-suppliers/speedisleeves
dobber
« Reply #419 on: March 18, 2012, 12:04:03 PM »
cheers fifer, on the phone Monday morn to them. got oil from the back again, just before i kicked its sorry ass i traced the trail. was coming from a corner of the rocker and working its way down.  i apologised to it immediately.
made a bracket for the rad using the rad mounts. then centered it and tacked it on.[ made sure i could get it off, not like the axle]
