April 06, 2026, 04:51:52 AM *
Pages: 1 ... 21 22 [23] 24 25 ... 43
Author Topic: dobbers trike  (Read 248552 times)
« Reply #330 on: January 26, 2012, 09:19:30 PM »
Looks great. Wonder what the beam pattern will be like with a triangular lens?
zakboy
« Reply #331 on: January 26, 2012, 09:24:56 PM »
yes i woundered what these head lamps would look like fitted....nice touch dobber
dobber
« Reply #332 on: January 26, 2012, 09:29:55 PM »
rodeo, just stripped it out completely and repainted all the floor red, then all the section where the toys sit grey. starting to build a 14ft spud unit monday from scratch, chassis custom made and galved to our spec then will build and fit to my neice,s spec. could run a thread on it.
havnt had power to head light yet mm, curious my self.
« Last Edit: January 26, 2012, 09:49:29 PM by dobber » Logged
        can i have it in 20 Min's?
dobber
« Reply #333 on: January 26, 2012, 09:33:04 PM »
got the little alloy side markers thru post. tried a little steel bracket mounted from mudguard mount but didnt like it.
dobber
« Reply #334 on: January 26, 2012, 09:39:34 PM »
found some stainless rod that fit in like a bike indicator stem, cut a short bit and drilled down center with 5mm, tapped it with a 6mm thread. put a stainless allen bolt with chromedome to clamp rod into the light then drilled the guard support with 6mm hole and a short allen bolt into the end of the stainless rod. looks reall neat. 500mm from floor and 290mm from furthest outside. [took little bracket off top mount and put coach bolt back in]
« Last Edit: January 26, 2012, 09:42:30 PM by dobber » Logged
dobber
« Reply #335 on: January 26, 2012, 09:45:51 PM »
hi zakboy. the whole headlamps a wierd shape. looks ok though.as said to mm will get it connected and see what occurs.
zakboy
« Reply #336 on: January 26, 2012, 09:54:07 PM »
hi mate, yes i like it gives that front end a nice touch  Wink
dobber
« Reply #337 on: January 26, 2012, 10:19:46 PM »
called at the stainless shop today to pick up some gear and got the owner to bend me some plates to mount the rear led lights and protect them from spray from the rear wheels. mount them tomorrow hopefully and more photos.
dobber
« Reply #338 on: January 28, 2012, 08:01:03 PM »
.cut a bit of flat bar to weld to the rear bar / bumper to mount the light box to. drilled it 5mm and tapped it 6mm then drilled the box to fit to the bar
« Last Edit: January 28, 2012, 08:03:35 PM by dobber » Logged
dobber
« Reply #339 on: January 28, 2012, 08:06:36 PM »
.tacked the bar on then bolted the box to it with two flat head type allen bolts in stainless so should be good for all the spray from wheels
« Last Edit: January 28, 2012, 08:51:47 PM by dobber » Logged
dobber
« Reply #340 on: January 28, 2012, 08:08:37 PM »
,needs a bit of shape to it. looks too square compared to curves on the rest of the machine
dobber
« Reply #341 on: January 28, 2012, 08:10:08 PM »
marked round a paint tin to get the curve then used cutter and then grinder to shape
« Last Edit: January 28, 2012, 08:12:22 PM by dobber » Logged
dobber
« Reply #342 on: January 28, 2012, 08:13:46 PM »
.got some stainless arc rods to weld corners then grind and polish it all up. will drill a hole below the light and feed the wires through the frame then back out as far up the frame as i can.
« Last Edit: January 28, 2012, 08:17:49 PM by dobber » Logged
zakboy
« Reply #343 on: January 28, 2012, 08:31:34 PM »
lights are looking good Dobber,..... your craking on with this now mate you cant be to far away with finishig this now can you
dobber
« Reply #344 on: January 28, 2012, 09:01:44 PM »
big problem now zakboy is getting the hand clutch lever sorted, got to admit iv been putting it off......  exhaust and rad will be easy enough. got to have some sort of flexi on exhaust or can i redo engine and box  mounts solid and have solid exhaust.  "discuss"... thinking of having a curved stainless plate round top of yolks and mounting some warning lamps in with a built in side lamp facing forward. would cover up ignition block now head lamp lot lower down.
