April 05, 2026, 04:38:30 PM *
Pages: 1 ... 6 7 [8] 9 10 ... 43
Author Topic: dobbers trike  (Read 248313 times)
« Reply #105 on: April 12, 2011, 09:40:21 PM »
You've been busy Dobber.
Al
« Reply #106 on: April 12, 2011, 10:34:17 PM »
looking good dobber no a bad idea making things in ply first
al
dobber
« Reply #107 on: April 13, 2011, 07:08:20 PM »
got seats back today. starting to look like something now. turned engine over today.turns quick for size of battery
        can i have it in 20 Min's?
zakboy
« Reply #108 on: April 13, 2011, 07:17:08 PM »
its defiantly coming together now dobber
dobber
« Reply #109 on: May 02, 2011, 03:42:35 PM »
found ten Min's to make the next mudguard bracket, only thing got done for weeks. stronger than i thought they would be..
dobber
« Reply #110 on: May 08, 2011, 06:37:05 PM »
thinking of making a battery box out of another extinguisher of same size as bottom tank. slice it long ways in half, put the same slot in the top for prop. weld in a strip all round bottom bit so top bit drops over it. could make it slightly taller to accommodate height of battery. would look good with two identical cylinders next to each other, easy to make water tight as well.
any one see any probs
« Last Edit: May 08, 2011, 06:39:36 PM by dobber » Logged
zakboy
« Reply #111 on: May 08, 2011, 06:43:26 PM »
are you using a standard size battery on the trike dobber
dobber
« Reply #112 on: May 08, 2011, 07:29:03 PM »
ended up getting a bike battery zakboy, amazing how quick it turns it.could have used the one from  the 900 donor bike but put it on my vn 1500 when that one went., made a mock up in ply for box but couldn't take to it. hornet was gonna price making it in stainless. think the curves of a cylinder are way to go tho now.. got a bit of time this week so scouting for a donor extinguisher to get going.
zakboy
« Reply #113 on: May 08, 2011, 07:38:21 PM »
 i think its a good idea dobber, it also makes it a bit diffrent to the standard box's will have a look when you post the pics
DIZZY
Ride it like you want it
« Reply #114 on: May 08, 2011, 11:18:36 PM »
I like that,makes for atidy job mate  Wink
Dizzy
dobber
« Reply #115 on: July 25, 2011, 10:10:11 AM »
found time to do a bit again. got the new axle with the conversion done. cut all the unnecessary off. gonna chop back off chassis n start again. making it a bit longer so if hit from behind the passenger ain't the first thing hit.
dobber
« Reply #116 on: July 25, 2011, 10:12:15 AM »
got a extinguisher for the battry box n lecci bits but turned out not to be symmetrical so ditched it
dobber
« Reply #117 on: July 30, 2011, 10:13:27 PM »
got axle off n chopped off ugly mounts i made. am gonna extend the back so the passenger ain't the first point of contact from a bump from the rear. hoping to put solid bar in the frame tube then extend with same frame tube. will be stronger and solid enough to mount axlel to.
if your reading this zakboy could you post a photo of your mounting set up, maybe give me a pointer.
zakboy
« Reply #118 on: July 31, 2011, 09:06:17 AM »
hi dobber, i have added some pic,s off the tubular frame when i was tacking it together if you can shape your frame at the back in a simler way this would be quite an easy way to mount your axle, as you can see i made the frame so i could insert some box section between the tube then simple mounted it with ubolts 4 in all when it was all lined up and bolted down i welded 2 to the axle to stop the axle turning at the mounting points and left the other to just bolted up makes it easy to remove and replace the axle should the need arise i also placed rubber between the mounting points on the frame and the axle to cut down on any vibration. but of course there are other ways you could mount the axle.all the best zak
zakboy
« Reply #119 on: July 31, 2011, 09:07:29 AM »
 Smiley
« Last Edit: July 31, 2011, 09:11:04 AM by zakboy » Logged
