March 23, 2026, 06:08:02 AM *
Author Topic: Bike lamps/ reflectors - dimensions and markings  (Read 2673 times)
Brant
« on: December 01, 2010, 08:01:16 AM »
Apologies for raising a topic question that must have been asked before but my search can't find a recent answer in the forum.
Question.  Do trike lamps and reflectors have to be of particular dimensions and carry approval markings (such as 'E')?  I'm Ok with lamp position dimensions but not size of actual lamps themselves.
The build (xv1100) is going in fits and starts but when finished I'll post a record with comments as to why and how I did it my way (thanks Frank).
thebigdogsix
« Reply #1 on: December 01, 2010, 08:38:24 AM »
Im not sure as to the answer of your question but you can download the MSVA manual and it would have your answer i would have thought
http://www.dft.gov.uk/vosa/publications/manualsandguides/vehicletestingmanualsandguides.htm#P58_1513
Brant
« Reply #2 on: December 01, 2010, 02:19:31 PM »
Thanks for the link.  Unfortunately free publications are limited to 'Guides', 'Forms', etc. and though position of lighting on a vehicle is given in a Guide no information on specifications/standards for lamps/reflectors is.  If there is a required standard for design and size of lamps/reflectors then I'm guessing it's in the SVA Inspection Manual which costs £37.
If a particular motorcycle to trike conversion does not require SVA inspection (mine does not, I think) then is SVA Inspection criteria important anyway?  Probably it is of more interest to me to know of the standards applied by an Inspector when I submit for vehicle document change from motorcycle to trike and thereafter the standards for MOT testing.
« Reply #3 on: December 01, 2010, 02:54:48 PM »
a lot depends on the tester.but to be safe use lights that are e marked.check out this link Undecided Undecided
http://motorcycleproducts.co.uk/catalogue/lights-indicators-c-200.html
thebigdogsix
« Reply #4 on: December 01, 2010, 03:10:25 PM »
No you can get the full manual for free
http://www.dft.gov.uk/vosa/repository/MSVA%202010%20.pdf
It was the third one on the sva list near the bottom
Brant
« Reply #5 on: December 01, 2010, 08:41:42 PM »
Thanks Terry.  Good link to supplier.
Brant
« Reply #6 on: December 01, 2010, 09:19:17 PM »
Not very bright am I (hence the question on lighting!).  I've now looked briefly at the Manual and so far as I can see it gives quite detailed  information for headlamps but little or nothing for other lamps other than suggesting 'E' mark for colour of lenses.
Interesting (for me) to note side reflectors are required and parking brake must operate on both wheels of an axle.
As I shan't be doing the MSVA I'm just left wondering how its standards might apply generally.
Thanks again Bigdogs for the link to the Manual.
