March 23, 2026, 04:08:33 PM *
Author Topic: rear axle  (Read 6375 times)
Al
« on: November 09, 2010, 02:30:15 PM »
hi everyone looking for advice iv got three axles but two of them are the same size and the other is smaller i was going to use the smaller one so was going to strip that one done to get hubs turned down but was wondering anyone know what axle it is from it is reliant but unsure what one also where can i get new bearings and oil seals
another question was has anyone changed the studs so that it would allow the wheel to be bolted with a bolt rather than a nut as unsure if the hub is thick enough for this to be done
anyhelp gratefully received
thanks al
« Reply #1 on: November 09, 2010, 09:04:12 PM »
Can you post some piccies of your mystery axles Siral.
Daddy Bear
The older i get the faster i waz
« Reply #2 on: November 09, 2010, 10:25:32 PM »
Hello chaps , may be the smaller one is of a bond bug , may be a thought .DB
Al
« Reply #3 on: December 08, 2010, 08:11:13 PM »
my dad asked me to upload these a while ago but just got round to it as he's in hospital,
http://i54.tinypic.com/5eu4af.jpg
http://i55.tinypic.com/10ril1e.jpg
http://i53.tinypic.com/dczrj9.jpg
http://i56.tinypic.com/166hv7s.jpg
thanks in advance
Al
« Reply #4 on: December 13, 2010, 12:25:21 PM »
thanks very much for that tb
does anyone know where i can get wheel bearings and seals for the axles at a not bad price
thanks al
« Reply #5 on: December 13, 2010, 06:28:27 PM »
try this guy or ebay.you will have to measure the bearing and seals first as theres at least two different sizes
http://carwisespares.moonfruit.com/
Dslam
« Reply #6 on: December 13, 2010, 06:54:04 PM »
You could try this lot as well, so long as you know the sizes. I have used them loads of times and they are fast and well priced.
http://simplybearings.co.uk/shop/
Good luck!!
Al
« Reply #7 on: December 13, 2010, 07:01:44 PM »
thanks i will do and check them tomorrow thanks al
Brant
« Reply #8 on: December 14, 2010, 11:12:16 AM »
thanks in advance
I'd be wary of http://i55.tinypic.com/10ril1e.jpg!!!  The half shaft tube seems to have been welded at some time and it's not concentric.  Any welder happy with such work should not be trusted and the axle is suspect.
Al
« Reply #9 on: December 14, 2010, 12:16:55 PM »
hi brant did notice that on that axle saw somewhere on here someone doing stainless or alloy sleeves for axles was going to try and get who it was that did them but wasnt going touch that axle till i get the other ones done im planning on doing three trikesin total 2 gs and one gt going to be busy and decide wich one i like but not going to start until january
« Reply #10 on: December 14, 2010, 01:19:47 PM »
haggis makes them
http://www.mankymonkeymotors.co.uk/forum/index.php?topic=93.msg71784#msg71784
Al
« Reply #11 on: December 14, 2010, 04:03:00 PM »
thanks terry t he is not that far away from me so would be ideal thanks
