April 17, 2026, 07:43:06 AM *
Author Topic: SU Carb Needle finder program  (Read 30217 times)
yoda
« on: August 07, 2005, 10:32:51 AM »
WinSU is a fantastic SU Carb Needle finder program
Follow link for more info
http://www.bikerlifestyle.co.uk/tech/winsu/winsu.htm
Yoda
a saveloy of the first order
« Reply #1 on: August 07, 2005, 12:57:31 PM »
Hmm, that could come in handy for us Reliant owning chappies.
wink100e
« Reply #2 on: August 11, 2008, 04:28:39 PM »
HI  all its been a while, (had the ex on my case) and been racing the robin so the trike parts got canibalised,
heres another link which you can compare SU needles on.
http://www.mintylamb.co.uk/suneedle/
« Reply #3 on: August 11, 2008, 04:38:31 PM »
Taaaa Grin um and welcome again Smiley
« Reply #4 on: August 11, 2008, 04:42:25 PM »
Yo! wink100e give us a shout when your next racing not been yet and your only up the road a bit.
wink100e
« Reply #5 on: August 11, 2008, 05:07:04 PM »
HI next race is BANK HOL MONDAY 25th, at MENDIPS raceway, shipham, A38 south of bristol
http://www.apwd.co.uk/joomla/index.php?option=com_frontpage&Itemid=1
JUST RELISED THE ROBINS WILL BE DOING A FIGURE OF 8 , better make sure the belts are done up tight
just to add a bit more fun there will be CARAVAN BANGER at end of day
« Reply #6 on: August 11, 2008, 07:43:04 PM »
Hiya Winky,
As we seem to have a major bias on this 'ere site towards Reliants, it'd be fantastic if we could have a race report & some piccies -any chance?
wink100e
« Reply #7 on: August 25, 2008, 12:20:24 AM »
have we found any gains from this site
sid
« Reply #8 on: November 11, 2008, 01:05:02 AM »
my son use to race mini's in grass raceing, i have a book some were that tells you what number carbs take what size's jets and needles would that be any help if i could find it.
« Reply #9 on: November 11, 2008, 05:54:36 AM »
I'm sure it would Sid, cheers.
« Reply #10 on: November 26, 2014, 05:16:44 PM »
I have made a spreadsheet comparing the usual jet needles { Spring Type } found on standard Reliant motors .
Needle Code ; AAT is the normal needle found on most 9.5 compression 850cc engines .
I have compared the following needles against the AAT .
Needle Code ; AEB is the needle found on most 10.5 compression 850cc engines often referred to as Yellow Tops .
Needle Code ; AAC is possibly the needle for 8.5 compression 850cc engines ?
Needle Code ; ABS is possibly the needle for 7.5 compression 850cc engines ?
Needle Code ; ABQ is an unknown needle I have in my collection of used carb spares so it has come out of a Robin or Rialto I have had ?
https://sites.google.com/site/fifersrelianthintstips/carb-su-carb-jet-needle-spring-type-comparison-of-4-common-needles
http://i423.photobucket.com/albums/pp316/fifer3w/SUCARBJETNEEDLESPRINGTYPE_zpsc461e7d0.jpg
« Last Edit: January 17, 2018, 12:35:41 AM by fifer » Logged
