April 29, 2024, 01:51:19 PM
Trike Tech
wheel PCD/Offset/tyre Speed/tyre size/ratio charts
3
Topic: wheel PCD/Offset/tyre Speed/tyre size/ratio charts (Read 46657 times)
yoda
August 07, 2005, 10:31:54 AM »
i have done a complete page on everything you need to know about trike (rear) wheels and tyres
it includes
PCD Chart
PCD/Offset Calculations
Tyre Speed Symbols & Categories
Tyre Size Calculator
Diff Ratio/Wheel Size Calc
http://www.mankymonkeymotors.co.uk/Tech/pcd/wheelstyres.htm
Yoda
Last Edit: August 08, 2005, 11:30:45 PM by yoda
http://www.bikerlifestyle.co.uk
a saveloy of the first order
Re: wheel PCD/Offset/tyre Speed/tyre size/ratio charts
August 07, 2005, 12:58:03 PM »
You Sir, are a genius.
foxthound
Piston broke
October 31, 2006, 02:35:56 PM »
That is brilliant! all in one place for once...THANKS
D'ya call that an engine?
October 31, 2006, 06:56:19 PM »
Welcome to the site mate.
flap
October 31, 2006, 07:42:05 PM »
Thats good that
Did you know I won a Trophy and lost my Cartman hat.
Then I won another Trophy. I miss my hat.
October 31, 2006, 07:45:09 PM »
Only just found it?
Check the posting date. That was posted over a year ago! Don't you lot bother reading this stuff?!
foxthound
Piston broke
Reply #6 on:
November 14, 2006, 02:39:53 PM »
Quote from: Manky Monkey on October 31, 2006, 06:56:19 PM
Cheers Manky Monkey!! Thanks for having me.
Reply #7 on:
January 18, 2007, 07:43:27 PM »
manfred
So many projects - so little time.....
Reply #8 on:
March 26, 2009, 05:09:41 PM »
Since I don't see it mentioned anywhere else, what's the bore for Reliant?
Over the hill and picking up speed on the long down-hill unto DEATH.
Reply #9 on:
March 26, 2009, 07:41:53 PM »
Hiya,
Bore as in engine bore? All the engine specs for the 850cc Reliant are in the Motors, 3 wheels bit of the main site.
Reliant engine specs
The 850, (actually 848cc), engine has a
bore of 2.46" (62.5mm)
stroke of 2.72" (69.09mm)
& compression ratio of 9.5:1
The 750cc engine, (748cc) has a
bore of 2.46" -same as the bigger engine
stroke of 2.4" (60.96mm)
& compression ratio of 7.5:1
manfred
Reply #10 on:
March 26, 2009, 09:53:05 PM »
Bore as in shoulder on hub, centre bore on wheel.
As if I'd be asking about reliant engine bore
Reply #11 on:
March 26, 2009, 10:07:04 PM »
Wondered why you were asking in this thread.
No idea. Both Taz's & my trikes have reworked hubs to take disc brakes, so haven't got a standard one to measure. Anyone?
manfred
Reply #12 on:
March 26, 2009, 11:01:34 PM »
That was the main reason for the question.
I don't have access to a press to remove the hub, so I'd like an idea of how much I need to remove from the disc.
Reply #13 on:
March 26, 2009, 11:23:16 PM »
Anyone got a standard Reliant hub about their person?
XJ750(UK)
Reply #14 on:
March 26, 2009, 11:32:09 PM »
are these the measurements you're after?
Last Edit: March 27, 2009, 12:15:12 AM by XJ750(UK)
3
