March 21, 2026, 06:00:34 PM *
Author Topic: Wiring etc........Couple of Q.s  (Read 3335 times)
RODeo
« on: August 02, 2010, 08:48:13 AM »
Hi All
 Blonde moment here ...(or grey in my case! Grin)..............Never wired hazards before ,only added the system to classic cars.....
 Hazard wiring...Will I only need one wire plus an earth to each indicator,and I presume a hazard relay does the indicators as well?
  Engine bolt threads.......Its soon time to pull the engine for the final tart up . Anyone know what thread the bolts are for the bellhousing ? UNF? UNC? or summat else? Also the thread for the g/box top plate bolts and the head bolts?Im going to do all bolts /nuts in s/steel.
   Thanx
« Reply #1 on: August 02, 2010, 09:37:59 AM »
Morning Rod, nice to hear your progressing...
Head Studs are 3/8" UNC into the block and 3/8" UNF on the other end
Bellhousing Studs are 5/16" UNC into the Bellhousing and 5/16" UNF on the other end
Gearbox top plate bolts are 1/4" UNC
Are you using a combined Indicator/Hazard flasher unit or 2 seperate ones?
« Reply #2 on: August 02, 2010, 10:45:04 AM »
ufc?  Grin
« Reply #3 on: August 02, 2010, 11:26:55 AM »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180386802413&ssPageName=STRK:MEWAX:IT
This might help take the pain out of the hazards for you
RODeo
« Reply #4 on: August 02, 2010, 02:27:57 PM »
Thanks for thread info TB.
 I had seen those hazard kits ,but 'cos Im doing everything from scratch, I havent got an existing set up to splice in to.
..............hmmmm ...just had another look at those kits..think I may get one then adapt it to fit .
« Last Edit: August 02, 2010, 03:03:28 PM by RODeo » Logged
twistgrip
« Reply #5 on: August 02, 2010, 03:02:07 PM »
Bit more expensive, but does provide a nicer handlebar switch.
http://indicator-buzzers.co.uk/index-3.php?region=uk
I'm in the same boat - gonna sort out front and rear indicators first, then splice this kit in afterwards.
David
Regards
David
