March 22, 2026, 09:48:29 PM *
Pages: 1 [2]
Author Topic: powdercoat  (Read 5122 times)
« Reply #15 on: November 12, 2010, 01:36:30 PM »
sorry morrag but newbury from south yorkshire is a bit of a journey, and as i,m sure andy will agree a trike frame is a bit too big to fit in a postmans bag! i,ll stick with the people i trust to do a good job and who are only a few miles away . even simpler !
Its all relative, when Grum was having his Pinto frame done he sent it from Stockport to the coaters that Desperate uses. Was a real qaulity job too. Uses Smoothrite myself though cos I is a cheapskate too Wink
VmaxTriker
« Reply #16 on: November 14, 2010, 03:21:57 AM »
Never been impressed with any powder coat finish, Two-pack paint is a lot more durable especially for the underside of trikes which take a battering..
Ignite the Vboost!!!
« Reply #17 on: November 14, 2010, 07:26:14 PM »
Powder-coat's quite soft. It tends to dent or scuff, rather than chip & flake like paint, & is usually thick enough to be able to buff surface damage out.
It's also reasonably petrol & brake fluid proof -prolonged exposure to either will soften it, but if you wipe it off with a wet cloth it usually survives unharmed. Any discolouration can be brought back with a spot of T Cut. Coating normally works out at about half the cost of paint. Biggest fault is the way water gets underneath it through any damaged areas & lifts it away from the metal.
As you say, it's down to personal choice, but I powder-coat everything I can these days.
Pages: 1 [2]
