April 12, 2026, 10:18:33 AM *
Pages: 1 2 3 [4] 5 6 7
Author Topic: Ford Popular 103e gone!!!  (Read 56376 times)
« Reply #45 on: August 08, 2010, 03:50:37 PM »
 Smiley Bless him. Everyone should have a garage mutt I think. I've got Lunatic instead.
Are you buying a new spring or have you already got one. I was looking at them in the Pop Browns catalogue the other day. My front one came from Speedway in the States, via Valley Gas Speed Shop in Newbury, Berks. Could you split the wishbone & run it down either side of the chassis as I did with the front one?
« Last Edit: August 08, 2010, 04:47:12 PM by Manky Monkey » Logged
« Reply #46 on: August 08, 2010, 04:27:45 PM »
trying to keep it as ford intended(near to as anyway)
going to use the spring thats under there already!
« Reply #47 on: August 08, 2010, 04:49:07 PM »
Cool. I can't even remember what mine looked like originally now.
« Reply #48 on: August 08, 2010, 05:57:14 PM »
i also want to take this away and use the stalk thats already fited.
this is the stalk. will i need to run a relay?
« Reply #49 on: August 08, 2010, 06:47:13 PM »
For those that don't remember them, that's a foot operated high beam switch. I haven't got room in my footwell to use one! What's the column stalk from Chris?
« Reply #50 on: August 08, 2010, 07:31:32 PM »
i've no idea what its from!!! was on there when it arrived.
got to make a surround for it, think i'll look in asdas to see what stainless pots etc are going cheap that i can modify!!!(and get 10% discount Grin)
« Reply #51 on: August 19, 2010, 07:28:00 PM »
well the parts pile is gettin bigger.
1300 kent x-flow ford engine, anglia 1200 box(long gear stick type) anglia axle, anglia hubs with vented discs, calipers etc.
money spent so far £15!!!! thats for the gearbox! other parts are what i had and kept back from swapping pop.
just got to find a few other bits.
twin choke carb(or a single not fussy!!!) anglia propshaft to start with.
rear tele shocks.
cheers chris.
« Reply #52 on: August 19, 2010, 10:25:54 PM »
15 quid?! I hate you, you know that don't you.  Tongue
Looking forward to this one.  Smiley
« Reply #53 on: August 21, 2010, 01:28:35 PM »
My anglia (my first car) had one of those foot operated dipswitches - sometimes I used it to change gear with!
« Reply #54 on: August 21, 2010, 06:54:08 PM »
Many years ago I used to work a few hours each afternoon for a neighbour who worked from home restoring classic Jags. Nearly wrote off an XK120 when I mistook the dipswitch for the brake pedal!
« Reply #55 on: August 21, 2010, 10:46:46 PM »
no chance of that as dipswitch is behind gearlever!!!
« Reply #56 on: August 31, 2010, 08:21:48 PM »
oops..............
« Reply #57 on: August 31, 2010, 08:25:36 PM »
Yep, it was on mine - but I still mistook it for the clutch pedal - more than once!  Didn't really seem to matter tho if the speed was right it just rolled through, used to do that with an ancient Austin lorry on the farm too!  (and that had no syncromesh at all!).
« Reply #58 on: August 31, 2010, 09:25:54 PM »
Front bumper Chris?
« Reply #59 on: August 31, 2010, 09:26:28 PM »
yep
