October 19, 2025, 10:40:39 AM *
Pages: 1 ... 23 24 [25] 26 27 ... 174
Author Topic: Manky's XS650 Yamaha  (Read 659848 times)
« Reply #360 on: November 15, 2012, 12:07:34 AM »
New manifolds.
« Reply #361 on: November 15, 2012, 12:08:38 AM »
Amals. Missing half the internals, but all available new from the Amal website.
« Reply #362 on: November 15, 2012, 11:47:23 AM »
They look nice, and fitting non-CV carbs give it an older/classic look too.  Always like the look. Wink
I've a set of roundslide mikunis to fit to mine (quite a common mod), they’re kinda the Japanese equivalent to the mkI Amals
Couldn't quite see if you had insulating blocks between the carb flange and manifold, but just in case you haven’t, I’d suggest it will be worth fitting them as the Triumph workshop manual shows the following assembly order for MkI Amals: carb, O-ring, insulating block, paper gasket, manifold.
One reason for insulating blocks (and in more modern times ‘rubber mounts) is to reduce the heat transfer from the cylinder head to carb,
The original XS650 CV carbs used ‘rubber’ adaptor mounts, and photos I've seen of XS650s with the roundslide mikuni conversion also use rubber mounts.
Really old (early 1900s) vintage bikes can actually boil the fuel in the carb when the bike is parked up after a run........... ask Dslam. We had to wait ages for the darling little bike to cool down!!  Grin
Photo shows original CV carb mounting
« Last Edit: November 15, 2012, 09:55:08 PM by Tony oily bike » Logged
Dslam
« Reply #363 on: November 15, 2012, 05:34:18 PM »
SMOKIN Grin
« Reply #364 on: November 15, 2012, 05:54:43 PM »
SMOKIN Grin
Well hopefully not Grin
fifer
« Reply #365 on: November 15, 2012, 08:21:07 PM »
Andy , a few questions on the Amals .
{ 1 } Are you going to be using separate cables or the single into 2 adaptor on the Amals ?
{ 2 } Gonna balance the 2 carbs up using lollipop sticks etc ?
{ 3 } Doing away with the choke slides { if fitted} and fitting blanks ?
{ 4 } Gonna fit the viton tipped needle valves ?
{ 5 } Gonna enjoy have petrol fingers again after a tickling session ?
« Reply #366 on: November 15, 2012, 09:56:52 PM »
Ahh, the joys of stinky fuely fingers!
I was going for the 1 into 2 cable set-up to operate the choke slides.
Cabman77
« Reply #367 on: November 17, 2012, 01:54:57 PM »
I think I`ve got a nice little chrome 2 to 1 able housing thingey somewhere. I`ll see if i can find it for you Andy, if you want it? Grin Grin Grin Grin
« Reply #368 on: November 17, 2012, 08:51:22 PM »
Yuss please Mr C.  Smiley
Various jets & needles ordered from the Amal website. Looking for insulating blocks now.
« Reply #369 on: November 17, 2012, 09:09:34 PM »
Andy,What size carbs are they,I have some insulating material here could make some.
« Reply #370 on: November 17, 2012, 09:28:46 PM »
It's O.K mate, just ordered some 3mm thick ones from Hitchcocks Motorcycles, thanks to a link from Dslam.
Ain't t'internet wonderful.  Smiley
« Reply #371 on: November 17, 2012, 09:53:19 PM »
No problem,Thestuff i have is thicker than 3mm,probably 12 or 14mm.
« Reply #372 on: November 18, 2012, 07:22:53 PM »
A quiet afternoon at the workshop today. Various bods there working on their own projects, so I was just tinkering.
Decided to quickly chuck the motor back in the frame to check the carb clearance. Quickly chuck it in -ha!! Big Darren & I struggled with it for over an hour & got absolutely nowhere -except he managed to pinch his big fingers between the engine & frame. Ouch. Could've been worse though. Could've been my fingers.
Even though the engine was in the frame when it was hardtailed, it looks like the bottom frame rails may have tweaked inwards a little during welding. In the end I had to sand the inside faces of the engine mounts with a soft pad on the angle grinder to clearance them. Still took 4 of us to get the motor in. XSs are bloomin' heavy old lumps. Gonna be fun doing it when the frame's painted.
« Reply #373 on: November 18, 2012, 07:28:26 PM »
The new cast aluminium carb manifolds aren't as sharply angled as the steel ones Pete started making when he built the hardtail. That means I have to fit 1" Amal bellmouths rather than the 3" ones I bought at the Popham Megameet back in August, otherwise they'd foul on the frame. Just as well the 3" ones I bought were the wrong size for the carbs I've got.  Tongue Anyone want a lovely pair of polished ali 3" bellmouths for 600 series Amal carbs?
« Reply #374 on: November 18, 2012, 07:30:09 PM »
This old exhaust flange is almost exactly the same as the standard Amal 1" intake.
