December 20, 2025, 01:26:12 AM *
Pages: 1 ... 22 23 [24] 25 26 ... 174
Author Topic: Manky's XS650 Yamaha  (Read 681676 times)
« Reply #345 on: November 11, 2012, 10:16:36 PM »
The flasher relay only has 2 pins.
Still not sure what this is, either an electric start relay or a regulator. Hopefully, either way, I don't need it.
« Reply #346 on: November 11, 2012, 10:17:13 PM »
It has this printed on the side.
« Reply #347 on: November 11, 2012, 10:17:48 PM »
Still don't know what this is either.
« Reply #348 on: November 11, 2012, 10:19:19 PM »
The finned thingy has the 8 way connector block & 7 wires you mentioned Tony, so is presumably a later combined rectifier/regulator.
« Last Edit: November 12, 2012, 08:53:52 PM by Manky Monkey » Logged
« Reply #349 on: November 12, 2012, 05:51:13 PM »
Some flasher relays have 2 pins, some have 3. I looked at ebay USA under XS650 parts
http://motors.shop.ebay.com/Motorcycle-Parts-/10063/i.html?_trkparms=65%253A12%257C39%253A1%257C72%253A4390&rt=nc&_nkw=xs+650&_dmpt=Motorcycles_Parts_Accessories&_sticky=1&_trksid=p4506.c0.m245&_sop=10&_sc=1
to try and identify parts I wasn't sure of, and that's where the pics of (XS650) the flasher relay came from, and they had 3.
The other widget - not really sure what it is, sorry.
If it's a regulator (ones I saw had the round piece on it as well), its not needed as you have the combined regulator/rectifier (the 8-way plug with 7 wires with big heat sink)
If its a relay for the starter, you still don't need it!
If its something else - Huh?
« Reply #350 on: November 12, 2012, 05:53:29 PM »
Me stumped on that one too................. Embarrassed
« Reply #351 on: November 12, 2012, 05:54:45 PM »
I beleive it is......... Cheesy
« Last Edit: November 12, 2012, 08:54:50 PM by Manky Monkey » Logged
« Reply #352 on: November 12, 2012, 06:02:35 PM »
So these are the parts I need to fit in my electrics box?
I'd say yes apart from the coil. Prob advisable to keep the HT away from the sensitive electronics of the Boyer and regulator/rectifier.
Guess you could have the box divided so the sensitive stuff is one side and the HT the other, but bear in mind the heat sink of the regulator/rectifier unit has disspate it's heat, and coil needs to be able to stay (relatively) cool too, which is why they're (the coils) are usually, to some degree, out in the open.
Personal view would be to mount the coil where the originals were.
« Reply #353 on: November 12, 2012, 09:05:42 PM »
The original pair of coils mounted on the bracing tube under the fuel tank, which we've replaced with a length of ERW tube cos it was so damn ugly & sits at an odd angle as standard, (normally hidden by the standard fuel tank). So I don't really want to put it there, but could sling it under the electrics box, along with the reg/rec unit.
Not sure if I've explained it well, but I plan to hang a platform under the seat for the electrics with the "box" simply a pair of covering side panels, (actually welded together at the front edge & held with a couple of Dzus fasteners). So I can make the platform half the depth of the side panels & mount components above & below it, but still hidden by the panels.
« Reply #354 on: November 12, 2012, 11:27:33 PM »
Your idea of coil position/mounting should be fine  Smiley sounds like where it'll be it should be protected from tyre spray too.
Worth double checking the coil you have has removable HT leads cos you're gonna need some long uns .............
« Reply #355 on: November 13, 2012, 06:47:43 PM »
Used to use inline HT lead joiners to extend leads. Basically a plastic tube with a brass screw in each end. Screw the old lead in one end & the new length in the other. Job done.
« Reply #356 on: November 13, 2012, 07:52:47 PM »
Used to sell loads of those, In the wet they were almost guaranteed to shock but the newer ones seem better waterproofed.
Still with the coils mounted under your arse you'd better be careful how you route the HT leads. Cheesy Wink
Firery Fred
« Reply #357 on: November 13, 2012, 07:53:56 PM »
Thanks people,I'll be needing all that info (for someone else to wire up me bike,thick me)
« Reply #358 on: November 13, 2012, 08:04:29 PM »
You don't have to be thick to need someone who knows what they're doing to wire up a bike!
« Reply #359 on: November 15, 2012, 12:05:19 AM »
Bought these a week or so ago from a guy on Ebay who casts pieces in aluminium.
Manifolds to fit my vintage British mark 1 Amal carbs to the Yamaha engine.
Original Mikuni carbs.
