April 28, 2024, 05:52:45 AM *
Pages: 1 ... 142 143 [144] 145 146 ... 174
Author Topic: Manky's XS650 Yamaha  (Read 549438 times)
« Reply #2145 on: October 12, 2017, 03:03:31 PM »
sorry just re-read the post, doh!. However, if you get stuck I'll call in a favour  Wink
mrhutch
« Reply #2146 on: October 12, 2017, 11:23:37 PM »
just use a small length of 10mm hose, and a reducer to 6mm ?
https://www.advancedfluidsolutions.co.uk/ekmps/shops/afsonline/images/13mm-10mm-1-2-3-8-brass-reducer-hose-connector-joiner-1339-p.jpg
« Reply #2147 on: October 13, 2017, 08:58:21 AM »
That's an idea.
« Reply #2148 on: October 14, 2017, 08:45:13 AM »
Pretty sure that the size will be 5/16" (could be wrong). Amal do 5/16" sized banjo fittings for the carbs.
« Reply #2149 on: October 14, 2017, 08:54:54 AM »
Aah, hadn't thought of that!
« Reply #2150 on: October 14, 2017, 10:21:13 AM »
5/16 equates to 7.9 or 8 mm, most decent rated fuel pipe at 8 mm. for unleaded should stretch out to a 10 mm barb I'd have thought. The old hot water trick?
« Reply #2151 on: October 14, 2017, 11:00:41 AM »
Definitely 3/8" & single banjos on the carbs, but I guess it wouldn't hurt to fit doubles, with a balance pipe between the carbs. I guess 5/16" hose would stretch to fit when warmed up.
Dslam
« Reply #2152 on: October 14, 2017, 08:54:24 PM »
If you are going to run a single tap, run the larger pipe to a T piece with smaller outlets to suit the carbs and get single banjo's for the carbs.
Just a thought.
« Reply #2153 on: October 15, 2017, 12:41:32 PM »
Two taps Andy. Just replacing the leaking one but can't find a direct replacement, so have gone up a size to something more easily available.
Dslam
« Reply #2154 on: October 15, 2017, 04:18:15 PM »
I'll get my coat Roll Eyes
« Reply #2155 on: October 15, 2017, 05:20:00 PM »
 Tongue
« Reply #2156 on: October 17, 2017, 08:57:28 AM »
Andy -no reason I shouldn't fit double banjos & a balance pipe is there?
Dslam
« Reply #2157 on: October 17, 2017, 04:18:49 PM »
None at all mate. Should be fine.
« Reply #2158 on: October 17, 2017, 08:28:39 PM »
Right-o.
« Reply #2159 on: October 17, 2017, 08:45:42 PM »
Will this fit.
http://www.vehicle-wiring-products.eu/product.php/1169/motorcycle-fuel-tap
