March 24, 2026, 07:20:01 AM *
Author Topic: my axle mount  (Read 7534 times)
« on: April 23, 2006, 06:22:43 PM »
we covered this in shiney`s post but didnt want to steal his thunder so am showing it here instead.
The mounting is 3" x 1" box section, a 2" circle is cut to take the axle then the top and bottom are notched for the fraim rails. The front is `locked off` with a strip of steel plate welded down the box and after welding in the rails the lips are bent over and welded again (belt n braces again lol )
The only mod i can think of would be to notch the fraim rails deeper and that would allow the lips tp meet in the middle and hence just need a single weld to cap it off.
« Last Edit: April 23, 2006, 06:32:43 PM by tbone » Logged
baldyshinehead
« Reply #1 on: April 23, 2006, 07:09:33 PM »
does that fix the axle permently or can it be removed
« Reply #2 on: April 23, 2006, 07:24:31 PM »
its a permant fix, that aint goin anywere wether it wants to or not lol.
i no for practical reasons that yours has to be removable, but generally i`ve neva seen the point. Reliant axles are pretty much bullet proof, thats y we use them, so maintenance isnt an issue.
« Reply #3 on: April 23, 2006, 10:10:55 PM »
We make ours removable so the frames can be powdercoated. This is the set up on Nige's frame, built about 4 1/2 years ago. Done thousands of miles all around the South of England with no problems. Sorry, mustn't keep jumping in -I'll let Nigel tell you about anything you need to know on this one!
« Reply #4 on: April 23, 2006, 10:12:12 PM »
But this is the rear mounted Fiesta radiator!
« Reply #5 on: April 23, 2006, 10:14:15 PM »
i like a man whose passionate about his work lol Cheesy. i like the way that looks, its neater and tidier than most mounts that i have seen used before
« Reply #6 on: April 23, 2006, 10:24:28 PM »
 Grin Somebody gave me the U bolts. No idea what they were intended for but they're 16mm diameter I think.
« Reply #7 on: April 24, 2006, 01:55:44 AM »
could  be commercial vehicle spring hanger bolts???
« Reply #8 on: April 24, 2006, 10:25:00 AM »
Entirely possible. I'd planned to re-use the original Reliant leaf spring U bolts -2 on each side, but these seemed the better option.
