March 24, 2026, 08:39:55 AM *
Pages: [1] 2 3 ... 5
Author Topic: GT750 build  (Read 36229 times)
baldyshinehead
« on: April 22, 2006, 10:01:07 PM »
Ok here goes, I have allways wanted to build a trike but have allways thought that due to lack of knowledge, funds and space I could never do it, untill I was offered a trike project GT750 with a reliant axle for the right price.
So off i go to pick it all the bits up, load up the van and start the treck home. Unload it all and set it out. Now what i had was a gt750 in bits and an axle, oh well, suppose i was hoping for a little too much for it to be started  Undecided
So far i have cut the bits i dont want off of the bike frame, got my hands on a prop shaft and set it all out level and in position.
Hopefully i will pluck up the courage soon to start cutting and tackingthe hardtail rear end onto the original cradle.
I will try to keep this updated as and when i do things
baldyshinehead
« Reply #1 on: April 22, 2006, 10:04:28 PM »
the first 2 pics are me making brum brum noises and my son doing the same  Grin
the next 2 are me and my brother setting it out and my boy again.
baldyshinehead
« Reply #2 on: April 22, 2006, 10:09:00 PM »
I had some erw laying about that i had been using to play with the welder so i thought i would mock up a rear end so I could better see what i had in my mind to do. Not straight, not welded well and not really anygood at all but it helped me visualise what i was trying to do with the back end.
And as the trike is ment to be for my wife it let her see what it would be like.
Speedmaster
« Reply #3 on: April 22, 2006, 10:15:21 PM »
Jeez, you guys always make it look and sound so easy, I could almost be tempted..........
baldyshinehead
« Reply #4 on: April 22, 2006, 10:17:36 PM »
easy ?  if it was i would have done it by now  Grin  scary is a much better word for it
« Reply #5 on: April 22, 2006, 10:18:30 PM »
That's interesting Baldy. Plenty of triangulation in the rear end which is always good to see. You going to use a solid slug between the old & new frame tubes?
Care to write a little bit about the wooden jig you've used to keep it all square? If you could scribble a few words of explanation & add a couple of piccies maybe Mr Yodles will add it to the Trike Tech bit.
Keep adding updates to the build here & when it's done we'll re-edit it & post it in the Motors, 3 Wheels section. Looking good so far.
baldyshinehead
« Reply #6 on: April 22, 2006, 10:21:03 PM »
the wooden frame thingy came with all the bits, I will try to find out more about it but i am sure it was in 100% mag .
the mock-up has no struts or any kind off strentgh to it so it will have more bits than in the pics
« Reply #7 on: April 22, 2006, 10:22:51 PM »
hey nice mock up baldyshinehead.
are you welding the upper n lower frame rails directly to the axle or you gonna clamp em round?
baldyshinehead
« Reply #8 on: April 22, 2006, 10:24:59 PM »
clamp them,  cant get it back through the house if its solid  Grin
Not sure on conecting the old and new tubes, my father in-law has loads more knowledge than i do so i will be asking his advice on such things.
« Reply #9 on: April 22, 2006, 10:25:30 PM »
the only extras i would consider would be a curved bar between the top n bottom rails, about midpoint but slightly one way or t`other wouldnt be a problem if it looks better.
baldyshinehead
« Reply #10 on: April 22, 2006, 10:29:01 PM »
This is where my odd mind comes into it lol.   I want to keep all the bars on the rear end straight,  partly due to not having a way to bend them but also because most people bend them ( if that makes sense ).  I didnt put any at the back in the mock-up because i didnt have any left  Wink
« Reply #11 on: April 22, 2006, 10:32:55 PM »
looks like you have used the old seat rail to mount the top tubes, yes?
if so the easiest way to join them is drill a 10mm hole right through the tube side on, then another one top to bottom, get yourself some solid steel bar that fits inside the tube, cut off six inches n slide 3inches into the tube then hold it in place by welding up 1 of the holes you drilled.drill your new rail the same way, slide it on and weld 1 of those holes too. i only weld 1 hole until i`m completely happy with the frame, its more work if you weld all 4 n then have to rip it apart cos u dont like it.
« Reply #12 on: April 22, 2006, 10:33:31 PM »
A few triangular gussets in some of the corners wouldn't go amiss either. No need to over complicate it though. Simple always works best. Yes, the wooden jig was in 100% but if you've still got yours it'd be nice to show it here for those who don't read the mag.
Speedy, it is simple! If I can do it anyone can! Just takes patience & a little common sense. What've you got to lose if it doesn't work out? Well, O.k, your life maybe, but what I mean is, 3 or 4mm wall thickness ERW, (Electrical Resistance Welded), tube is about 2 quid a foot, a 150 amp MIG welder will cost you about 150 - 200 quid, (Desperate Dan sold his on this 'ere forum just recently for 90 quid I think), your local Tech College will do an evening class to teach you how to use it, an old Jap donor bike & away you go. Go on -you know you want to!
baldyshinehead
« Reply #13 on: April 22, 2006, 10:34:49 PM »
you have got it spot on.  that is what i was going to do there, it is the bottom rails i am not so sure on.
« Reply #14 on: April 22, 2006, 10:35:38 PM »
i see wot ur thinkin, the reason most are bent is because a bent tube will flex better under the forces actin on it than a staight one. If your set on straight tho, i would consider a triangle rather than just a single tube.
