April 16, 2026, 03:24:33 PM *
Author Topic: Fuel Pipe  (Read 4393 times)
« on: April 10, 2010, 06:07:07 PM »
May be a silly question but is copper brake pipe okay to use for fuel pipe?
« Reply #1 on: April 10, 2010, 07:24:05 PM »
Shouldn`t be a problem they used copper fuel lines on beetles for years.
« Reply #2 on: April 10, 2010, 08:47:33 PM »
Thats a new one on me but then i havent had anything to do with beetles, i can say tho that steel pipe has been used for fuel lines for years.
« Reply #3 on: April 10, 2010, 08:50:03 PM »
All pre. and 'just' post war bikes used copper fuel lines and brass fittings,so no probs.  Morrag
« Reply #4 on: April 10, 2010, 09:15:54 PM »
Is brake pipe going to be big enough diameter for fuel pipe?  Don't want you suffering from starvation!!!
« Reply #5 on: April 11, 2010, 09:06:30 AM »
I will see what ID the brake pipe I have is. I saw copper fuel pipes on Minisport and just wondered if it was the same grade as brake pipe.
cunningplan
« Reply #6 on: April 14, 2010, 05:55:06 PM »
I use 8mm microbore central heating copper pipe for my car, brake pipe will be to small.
voodoo
« Reply #7 on: April 15, 2010, 10:08:59 AM »
I will be running 90% of the brake lines/fuel lines etc in copper on Terri's trike once we get stuck in on it...so nice someone started this thread......Voodoo......
Custom Paint Spraying...
« Reply #8 on: April 15, 2010, 06:42:45 PM »
I'm planning something similar for Taz's trike too. Great Monkey minds think alike eh.  Smiley
Hadn't thought of using copper for the fuel lines though. The fuel doesn't react with it in any way then? I was just going to use it for the brake & water pipes.
« Last Edit: April 15, 2010, 06:44:26 PM by Manky Monkey » Logged
gpz
« Reply #9 on: April 15, 2010, 08:39:09 PM »
you could use 10mm copper the same stuff that is used for oil boilers that is not affected by the diesel oil so cant see why unleaded shoule affect it
voodoo
« Reply #10 on: April 16, 2010, 08:13:23 AM »
Ive had copper fuel lines on a few of my customs over the years and never had any problems with it.....make sure you get a decent size or you wont be getting enough fuel...Voodoo...
o0Mouse0o
« Reply #11 on: April 16, 2010, 02:14:43 PM »
I've had trouble with copper fuel tube fatigue cracking if you don't strap it down to stop the vibrations.
voodoo
« Reply #12 on: April 16, 2010, 02:22:11 PM »
I normally use P clips to hold it in place so never had that problem as yet....Voodoo....
