April 16, 2026, 06:39:52 AM *
Author Topic: chopper builders handbook bender  (Read 5531 times)
« on: March 29, 2010, 03:43:02 PM »
anyone made one of these?
i started mine today as i have 3 hours of un supervised time at work fo rthe next 2 weeks and we had a lump of 2inch by half inch stainless flatbar taking up real estate
actually the bolts and all will be stainless as thats all we use at work
will post pics hoping to finish tomorrow
plan download http://chopperhandbook.com/neatstuff/
« Reply #1 on: March 29, 2010, 06:17:42 PM »
Would be interested in seeing that Chewie.
« Reply #2 on: March 30, 2010, 12:29:00 PM »
pfffft
no completion today. actually had to work! also discovered i'd cocked the spacer tubes and the drill press at work is out of true.
wont work on it tomorrow as i'm doing an early shift (gettin away early for me birfdy)
bugger
voodoo
« Reply #3 on: March 31, 2010, 05:59:03 PM »
Very good builders guides on that site....I will enjoy having a proper read through them...Voodoo...
Custom Paint Spraying...
« Reply #4 on: April 05, 2010, 12:28:03 PM »
spent 5 hours at public holiday rates on the lathe today, cant believe i want to quit this job!
pics to come of partially completed die
« Reply #5 on: April 05, 2010, 02:42:17 PM »
the blank is 50mm X 230mm
ok so after i discovered a warp in my steel i had to cut 5mm off it to get one flat side
http://i49.photobucket.com/albums/f291/chewie66666/bender/cid_187.jpg
then i centred and drilled it out to 25mm
http://i49.photobucket.com/albums/f291/chewie66666/bender/cid_185.jpg
then i used the live centre to set the tool tip out to 3 inch (yes i do mix my measurements) and scribe a mark for the drive pivot holes
http://i49.photobucket.com/albums/f291/chewie66666/bender/cid_186.jpg
next step is to mark and drill pivot holes and then turn the 32mm semi-circle onto the outer edge
good fun
« Reply #6 on: April 05, 2010, 10:17:27 PM »
I've no idea what's going on here, but I like shiny stuff.  Tongue
