December 19, 2025, 02:03:31 PM *
Pages: 1 2 [3]
Author Topic: Mouse's Build  (Read 11586 times)
Plasticpig
« Reply #30 on: April 08, 2010, 03:01:04 PM »
Mouse ripped off the right hand cylinder and found some possible previous damage around the join, and  some scoring in the bore. After further stripping he found plenty of oil in the sump so it was not a serious sieze.
Has since taken it to a local company and was quoted a good price for a rebore.
I will nag him to give us an update asap.
« Reply #31 on: April 08, 2010, 05:41:35 PM »
I do like your layshaft set up, I have plans for an electric hacksaw that uses con rods somewhere.
afghanman
« Reply #32 on: April 15, 2010, 11:09:35 AM »
Just out of curiosity, why did you mount the engine across the frame? and not front to back.
I would have thought it would have been less work drive wise.
But then again I know nothing Roll Eyes
pkdsculpture.moonfruit.com
o0Mouse0o
« Reply #33 on: June 01, 2010, 11:42:01 AM »
Just out of curiosity, why did you mount the engine across the frame? and not front to back....
This was the orientation of the original engine so to connect it to the gearbox I only needed to make an adaptor.
o0Mouse0o
« Reply #34 on: June 01, 2010, 11:49:31 AM »
The overheating on one side was tracked down to a little valve thing bit that opened when the decompressor was operated that dropped a drop of oil into the inlet manifold. The 35 year old rubber had gone hard and as a result it was continuously dribbling sump oil into the intake and over fuelling the engine which I've learned is a very very bad thing for a diesel engine. It was a simple fix that took 10 mins but I think the damage had already been done by this point. This would also explain why it was so hyper sensitive to crank breathing / pressure and I had resorted to having a rag stretched over the oil filler to stop it smoking badly. After this fix the cylinder head temperature dropped and both were between 120°C and 145°c depending on the conditions and it even sounded like it was running a lot better, it was certainly more responsive.
Prior to the last and final fail I had got it working very well. It was starting straight off the button and running well and for a brief moment I had it at the staggering speed of a mile a minute. The last outing was in idyllic late afternoon summer sun and warmth through some country roads and then over the old Severn bridge to Bristol which including a few stops to check temperatures took about an hour. I thoroughly enjoyed it and the bike was running well and was everything I dreamt it would be.
The engine then died again when I tried to start it to return home. No compression which could have been something simple but as I couldn't start it the recovery bloke came and took me home. When I took the head and barrel off of it the piston skirt was cracked. However further investigation reviled a warped and badly distorted cylinder head which had ultimately resulted in the piston contacting the head and causing the cracked skirt. I never got to the bottom of why the valve clearances keeped closing up but a softened head that was distorting would explain it. I suspect the ally head was over heated before I got the engine or during one of the more unsuccessful outings.
Spares are hard to get and very very expensive. So that's the end of the line for that particular engine and indeed the whole project.
I've now given up hope on the whole engine as a badun.
RIP the V Twin Diesel Project.  Cry
« Reply #35 on: June 01, 2010, 10:25:24 PM »
That's a shame Mouse -sounded like it had real promise.
« Reply #36 on: June 01, 2010, 10:45:58 PM »
Well, that's another piece of lateral thinking sadly reaching an all too early demise, but while it lasted it showed great promise and ingenuity Mousey, and a credit to the tradition of "suck it and see" Engineering endeavor! I await your next scheme with interest, and trust that it will be similarly diametrically opposed to the more familiar "bling" concept of customising,i.e acres of shiny paint, but little novelty, as this effort, more strength to y'all,.......Morrag
Pages: 1 2 [3]
