April 13, 2026, 02:37:13 PM *
Author Topic: HELP  (Read 4324 times)
« on: February 18, 2010, 05:48:41 PM »
Need help fast, My GS850 has decided to run like crap in the wet, replaced plugs and air filters, same problem but noticed tonight that not long after start up the exhausts on cylinders 2 and 3 are glowing red hot any ideas?
cunningplan
« Reply #1 on: February 18, 2010, 06:13:28 PM »
running to lean!!!! check the carbs
« Reply #2 on: February 18, 2010, 06:22:48 PM »
Thanks Tony that's what I thought but needed second opinion.
 Angry
trikerpete
« Reply #3 on: February 20, 2010, 09:56:45 PM »
doc, what carbs and filters are you running?
« Reply #4 on: February 21, 2010, 05:51:28 PM »
Standard Carbs and S&B filters + air correction kit.
ByzMax
Choppit
« Reply #5 on: February 23, 2010, 07:26:16 PM »
Get the carbs off and give em a blow through..  Wink
http://www.choppit.co.uk
cunningplan
« Reply #6 on: February 23, 2010, 09:15:07 PM »
I bet thats what you say to all the ladys  Roll Eyes
gsxrsam
« Reply #7 on: February 24, 2010, 08:06:39 AM »
also check ignition cover for water ingress...
« Reply #8 on: February 24, 2010, 06:56:41 PM »
Turns out that the new air filters are less restrictive than the S&B's that i had and was making the engine run lean, it didn't occur to me that there would be that much of a difference between air filters of a similar type.
So I have replaced the old filters and it's back working fine again, oh and one of the new plugs was faulty and an HT lead was shorting out.
