April 13, 2026, 01:06:29 PM
General Tech
HELP
Topic: HELP (Read 4318 times)
HELP
February 18, 2010, 05:48:41 PM »
Need help fast, My GS850 has decided to run like crap in the wet, replaced plugs and air filters, same problem but noticed tonight that not long after start up the exhausts on cylinders 2 and 3 are glowing red hot any ideas?
cunningplan
Re: HELP
February 18, 2010, 06:13:28 PM »
Quote from: TwistedPatience on February 18, 2010, 05:48:41 PM
running to lean!!!! check the carbs
Re: HELP
February 18, 2010, 06:22:48 PM »
Thanks Tony that's what I thought but needed second opinion.
Re: HELP
February 20, 2010, 09:56:45 PM »
doc, what carbs and filters are you running?
Re: HELP
February 21, 2010, 05:51:28 PM »
Standard Carbs and S&B filters + air correction kit.
Re: HELP
February 23, 2010, 07:26:16 PM »
Get the carbs off and give em a blow through..
http://www.choppit.co.uk
cunningplan
Re: HELP
Reply #6 on:
February 23, 2010, 09:15:07 PM »
Quote from: ByzMax on February 23, 2010, 07:26:16 PM
I bet thats what you say to all the ladys
gsxrsam
Re: HELP
Reply #7 on:
February 24, 2010, 08:06:39 AM »
also check ignition cover for water ingress...
Re: HELP
Reply #8 on:
February 24, 2010, 06:56:41 PM »
Turns out that the new air filters are less restrictive than the S&B's that i had and was making the engine run lean, it didn't occur to me that there would be that much of a difference between air filters of a similar type.
So I have replaced the old filters and it's back working fine again, oh and one of the new plugs was faulty and an HT lead was shorting out.
