March 03, 2026, 09:12:30 AM *
Pages: 1 ... 4 5 [6] 7 8 ... 106
Author Topic: Manky's new Reliant trike.  (Read 395626 times)
ByzMax
Choppit
« Reply #75 on: July 19, 2006, 10:45:54 PM »
It's a testament to your skills and patience to be able to turn out such fab looking trikes in such restrictve conditions. Grin Grin
http://www.choppit.co.uk
« Reply #76 on: July 19, 2006, 10:47:36 PM »
If I had the machinery I wouldn't know how to use it anyway!
ByzMax
Choppit
« Reply #77 on: July 19, 2006, 10:55:18 PM »
The MSVA manual's in the garage but I'll see if I can find the relevant page again next time I'm there. I'm sure it says something about them having to be on a seperate switch.
I think it's that they must not operate from the ignition switch??? When I put my last trike through I specificaly asked about this before wiring up the trike and it was not required. Bikes don't need it but cars do.
« Reply #78 on: July 19, 2006, 11:01:34 PM »
The regs are fairly straight forward but there's still plenty of room for misinterpretation isn't there!
Right, I'm outta here for the night chaps. My alarm goes off in 3 hours time.
G'night all.   Smiley
ByzMax
Choppit
« Reply #79 on: July 19, 2006, 11:04:06 PM »
It's can be a bit confusing. But gets easier as time goes by.
« Reply #80 on: July 19, 2006, 11:04:57 PM »
I've got a life like that.
brock
« Reply #81 on: July 19, 2006, 11:24:07 PM »
last one I had MOT'd failed first time on the side light thing, ended up just putting a plate under the headlight with a small running light separately fed and switched, put the switch in the battery box, no regs covering it's position, and pulled the fuse once tested.
« Reply #82 on: July 20, 2006, 03:19:01 PM »
O.K, so trikes do need sidelights that can be operated with the ignition turned off, ie, not by the ignition switch -is that what we're saying? So the normal handlebar switch permanently fed would be O.K?
rainbow
« Reply #83 on: July 20, 2006, 03:58:26 PM »
Spent a couple of hours in the garage yesterday but it was like an oven in there- too hot to do much except perspire profusely. Knocked up a little plate to hold the radiator fan. I'm using an electric bike rad fan of unknown origin. This'll be hidden behind the radiator when it's finished.
That looking good Andy Smiley
« Reply #84 on: July 20, 2006, 04:08:13 PM »
Hello stranger.  Smiley
ByzMax
Choppit
« Reply #85 on: July 20, 2006, 07:49:06 PM »
As far as I'm aware but will get the gospel tomorrow.
You MUST have marker lights and a  small backup Side/Running light in the headlamp or seperate.
Your lights must operate from switches other than the ignition switch.
You must have Side light dipped and main beam.
Their  was no specification that any of the lights other than the Hazard lights have to operate without the ignition switched on.
My Last Trike that I put through the MSVA did not have lights that operated with the ignition off.
Lights do not need to be EU approved or have any other kind of approval but must visually perform to the standard of an approved light.
If the Trike is over 1.7m wide then it must have 2 headlamps like a car.
If Under 1.7m wide then a single headlamp is acceptable.
Forward facing white marker lights are required
Forward and rear facing indicators.
Rear facing stop and tail lights
Rear facing fog lamp x1
Number plate lamp.
Forward facing indicators are fine mounted on the rear mudguards or in the general area..
Stop and tail lights, indicators, and marker lights must be mounted no further than 400mm from the extreme outer edge of the vehicle at it's widest point.
(The measurement is taken from the edge of nearest edge of the illuminated area not the body of the lamp (Beware)
Fog lamp must be mounted either in the centre line of the vehicle ar to the off side.
Number plate should be mounted on the centre line of the the trike.
Finaly........ IF YOU HAVE LED's MOUNTED ON YOUR FRAME TO ILLUMINATE BITS OF YOUR TRIKE. DISCONNECT THEM. YOU MAY FAIL IF THE ARE FOUND!!!!!!
ska-man2
« Reply #86 on: July 20, 2006, 09:04:45 PM »
That means I have done something right then Grin when wiring the trike. dose that mean I may call my self a trike builder now.....Ha Ha
« Reply #87 on: July 20, 2006, 10:03:36 PM »
Umm, you've just stated the lights, other than hazards, don't have to operate independent of the ignition switch -so they don't have to be live all the time then?
Fog lights are only required on trikes over 1700 wide aren't they? Don't have to be fitted to narrow trikes but must work if they are.
Didn't know the number plate has to be centrally mounted -just as well I'd planned to do that anyway. Interesting point about the lights not having to be E marked too. I was worried my rear ones weren't but they're BS marked anyway.
« Last Edit: July 21, 2006, 05:40:06 PM by Manky Monkey » Logged
ByzMax
Choppit
« Reply #88 on: July 20, 2006, 10:22:56 PM »
One rear fog light required on all trikes Sad
Only the Hazard lights need to work with the ignition off Grin
« Reply #89 on: July 20, 2006, 10:50:49 PM »
Quote from Chris, an MSVA inspector who advises on the 100% Biker forum:
Rear fog: Not obligatory but if fitted must be red Min height to bottom of lamp 250mm (not centre of lamp) max to top 1000mm. Must have tell tale warning lamp.
