« Reply #270 on: December 24, 2006, 07:01:45 PM » |
« Reply #271 on: December 24, 2006, 07:02:42 PM » |
« Reply #272 on: December 28, 2006, 10:30:22 PM » |
Back in the garage this evening, I cut out & welded an end cap on my speedo pod thingy.
davesatan
« Reply #273 on: December 29, 2006, 09:51:33 AM » |
i want one
how long is a piece of hope
« Reply #274 on: December 29, 2006, 11:17:25 AM » |
One what exactly? I'm off to visit Mr SaddleBags in his Shiny Thing Grotto again later. He's drilled the top yoke to accept my bars.
davesatan
« Reply #275 on: December 29, 2006, 11:56:42 AM » |
one of your frames
« Reply #276 on: December 29, 2006, 01:19:34 PM » |
Ahh. Much sought after they are.  We've got to build one for Mr Bags in the very near future, down at Saddlebags Enterprises inc. Gather your parts together & we could build 2 at the same time. What's the chances of us getting the parts mixed up & fitting your axle to his frame?!
saddlebags
« Reply #277 on: December 29, 2006, 01:36:52 PM » |
There is absolutely no chance of getting any of my parts mixed up with anyone elses,mine are shiny!!!
« Reply #278 on: December 29, 2006, 01:41:27 PM » |
 Get back to work you! Many shiny things to make, you have.
« Last Edit: December 29, 2006, 02:29:00 PM by Manky Monkey »
« Reply #279 on: December 29, 2006, 01:42:36 PM » |
Hey, I forgot to ask this morning -what magic did you use to remove that drill bit I busted off in my yoke?
« Reply #280 on: December 29, 2006, 02:53:21 PM » |
davesatan
« Reply #281 on: December 29, 2006, 03:37:31 PM » |
Ahh. Much sought after they are.  We've got to build one for Mr Bags in the very near future, down at Saddlebags Enterprises inc. Gather your parts together & we could build 2 at the same time. What's the chances of us getting the parts mixed up & fitting your axle to his frame?! got engine gear box tank yokes axle prop electrics need forks and front wheel
« Reply #282 on: December 29, 2006, 03:41:28 PM » |
Must be someone here with spares?
« Reply #283 on: December 29, 2006, 10:23:13 PM » |
Well, one step forward & another back tonight. That's about normal really. Collected my yoke from Mr Bags this afternoon. He's drilled it for the handlebar bolts, with countersunk holes so the allen bolt heads finish flush with the underside of the yoke. Then he's countersunk the top face so that the risers slot into the yoke, rather than just bolting to it. Very nice. Then I buggered it up. Screwed the bolts into the risers. No problem. Unscrewed them. Argh! One came out easily but the other jammed. No idea why -like it was cross-threaded but it went in O.K. It ended up seizing completely. Couldn't even budge it with my favourite hammer. Could've given it back to Mr Bags to drill out & retap for me but it was easier to just cut the end off the riser & make up a new captive nut. That's done so I'll weld it in tomorrow & be back where I was before I started tonight. Ho hum. Anyway, here's a couple of snaps of the story so far.
« Reply #284 on: December 29, 2006, 10:28:48 PM » |
I've taken the fork top nuts off to remove the top yoke, so the front end's sunk a few inches in these piccies. Not really much more to add to the frame now. Master cylinder mounts. Clutch slave cylinder mount. Battery box mounts. A bit of filing & general cleaning up then it's ready for powder coating, but while it's all together I'll also make up the handbrake cable mounts that will weld to the axle & the steering stops on the bottom yoke. Also the master cylinder reservoir mounts that will bolt to the top of the gearbox. It's getting there -slowly.
« Last Edit: December 29, 2006, 10:30:49 PM by Manky Monkey »
