December 23, 2025, 03:16:26 AM
Trike Tech
rockstars build the story so far
Pages:
Topic: rockstars build the story so far (Read 6427 times)
rockstar
Re: rockstars build the story so far
Reply #15 on:
December 31, 2009, 10:49:10 PM »
yes the tabs were originaly part of the clamps i just cut one bolt holes worth off and welded it to the axle i may be able to help with sight glass i know of some tube but fittings may be a prob give me acouple of days after new year and i will see what i can find
if you dont know you should try coz if you dont try you wont know
Reply #16 on:
December 31, 2009, 10:58:37 PM »
Cheers. Postal address please.
bitzman5
Reply #17 on:
January 01, 2010, 02:21:27 AM »
HI MM when i built the blitz i had a site tube down the side consisting of one wheel valve with the valve core took out at the top and bottom place tube between and a small ball that petrol does not destroy acting as a float level from empty put in 1 gallon of fuel mark tube continue till full marking each gallon put in there u go cheap site glass and accurate
Reply #18 on:
January 01, 2010, 08:08:17 AM »
That's the sort of thing I was thinking of, but not sure of the end fittings & how to seal the tube into them or seal the fitings into the tank.
peanut
Reply #19 on:
January 01, 2010, 10:33:04 AM »
I will also be installing a sight-tube at some point into my spun-alloy tank. I aim to have a bung welded into the bottom so that I can thread it for a small elbow just like those bent tyre valve adaptors and fit a corresponding tube in the side of the filler neck. I just have to source some clear tube that hasn't got the mesh reinforcment and that won't go yellow. I saw the article in Custom Car about those Pyrex water pipes but that might be asking for trouble if it got smashed miles from anywhere.
lunatic
Reply #20 on:
January 01, 2010, 03:14:44 PM »
There is a translucent red fuel pipe that you can get from hot rod shops, that might work. Though it may be a bit hard to see the level?
pat
Reply #21 on:
January 01, 2010, 08:42:40 PM »
Rockstar,you are doing a great job. Wish I was as far forward. I would like to know is this a hardtail?. From your pics it seems to be, why I'm askin is because I cant figure what the shock absorbers are for at the back, what are they attached to at the top?. I was thinking of attaching a seat frame to the bike frame with bushings and putting shocks roughly the same as yours at the back. But your frame seems to be welded solid at the front. Maybe I am missing something here.
Pat
Reply #22 on:
January 02, 2010, 02:05:32 PM »
Mike, (Rockstar). The disc was posted to you yesterday. Some areas of the country are getting mail pretty promptly at the moment & some have a bit of a backlog, but hopefully it'll be with you soon.
rockstar
Reply #23 on:
January 03, 2010, 07:36:20 PM »
thanks MM still waiting for stuff pre christmas still getting bills though
hi pat my project is softail home made swingarm that pivots in the frame in the shoe shaped plates as in this photo none of this has been tried yet seems to work ok stationary need to finsh of brakes and temp wireing so i can take it to one of our large sites to test ride it not too long away now
pat
Reply #24 on:
January 03, 2010, 09:39:45 PM »
Doooh, see it now, the whole axle can rise and fall and the seats are not sprung. Lot wider than a bike swingarm so should be a lot stronger. Hope this works.
pat
Pages:
