December 23, 2025, 03:09:06 AM *
Author Topic: hazard lights  (Read 1615 times)
cowboy
at your peril
« on: December 14, 2009, 07:49:40 PM »
Can anyone tell me whether a trike registered in 1975 need hazard lights?Huh??
cowboy
« Reply #1 on: December 14, 2009, 07:59:48 PM »
The Road Vehicles Lighting Regulations 1989. although amended in 2005 there is no applicable amendment to regulation 18.
Statutory Instrument 1989 No. 1796
Hazard warning signal device.............Exceptions........A vehicle not required to be fitted with direction indicators. A vehicle first used before 1st April 1986.
« Last Edit: December 14, 2009, 08:06:38 PM by tbone » Logged
klogan45
« Reply #2 on: December 14, 2009, 08:20:57 PM »
Hello Tbone, am I reading this right in so far as that if a bike registered before 1st april 1986 is converted to a trike it don't need hazards, or would the date be taken from the 1st MOT as a trike? Sorry if I seem a bit stoopid, it's not intentional, it just happens!!!!
Regards
K
« Reply #3 on: December 14, 2009, 08:56:37 PM »
Hiya K, how you doin?  Grin
Obviously if the conversion required an MSVA then hazards would be needed, cos you have to comply with current regs.
If we are talking bolt on conversion, you still need the wheelplan changed on the V5C, i`ve not done one since the change in regs, but i`d say that if they record the date of the wheelplan change, then yes, hazards would be needed, because again, the new wheelplan change would have to meet with current build regs. Just my thoughts on the subject though, unless anyone knows different.
