April 07, 2026, 04:01:59 AM *
Author Topic: granada axle  (Read 3076 times)
« on: December 07, 2009, 11:06:39 PM »
Hi all,thought it was about time i showed my face so to speak,
i registered in august but have just been reading and learning,
a lot of clever people on this site.
anyway down to my question,How much difference is there between the granada and sierra.
physical size,ratio.
« Reply #1 on: December 08, 2009, 10:18:08 AM »
Simple answer.... bugger all size wise between the vehicles Wink.
But the Granada also ran a 3.92:1 ratio.
Drum braked vehicles all ran a 7" diff with push in type shafts, while disc braked vehicles had the option of 7" or 7.5" diffs and the shafts bolt to the diff.
« Last Edit: December 08, 2009, 10:32:47 AM by tbone » Logged
« Reply #2 on: December 08, 2009, 11:11:18 AM »
Thanks for the reply thone.
there's a scrap yard near me that has an M plate car,the axle has discs so bolt on drivshafts,
« Reply #3 on: December 08, 2009, 11:26:44 AM »
Welcome aboard by the way, i forgot to say that, its my age you know  Roll Eyes
Originaly the diff would have had a tag attached to one of the housing bolts, the tag would have had the ratio marked on it, but inevitably the tags vanish over time. As with most (all?) Ford diffs though, they do take the time and trouble to stamp the ratio in the gear, but that means pulling the plate off the diff to get inside.
See the attached pic to tell the difference between the 2 different diff sizes.
« Last Edit: December 08, 2009, 11:32:16 AM by tbone » Logged
« Reply #4 on: December 08, 2009, 12:12:03 PM »
thanks for the welcome tbone,          and don't worry about it i'm getting the age thing myself,
if i dont hurry and get on with this build i'll forget wot i set out to do and end up with a zimmer,
apart from the ratio what differance will the 7"and 71/2"make to the build.
« Reply #5 on: December 08, 2009, 01:05:06 PM »
Welcome to the world of mankeyisms.......... Wink
« Reply #6 on: December 08, 2009, 06:18:23 PM »
No difference at all  Wink
« Reply #7 on: December 08, 2009, 08:40:27 PM »
I had better go and get it then,
thanks again tbone.
and thanks for the welcome ROD.
