April 07, 2026, 08:34:55 AM
Trike Tech
MSVA QUERY....
Topic: MSVA QUERY.... (Read 2755 times)
MSVA QUERY....
December 06, 2009, 08:26:35 PM »
I presume when doing the msva test the handlebars are held on full lock,left and right to see what the 'sausage' on wheels touches? In my case the footpegs are protruding past the handlebar when on full lock,so I will have to radius the peg ends to suit . Are some builds having trouble with the carb /airfilter/bellmouth fouling? And is this why they have been turned to face front? I calculate that with the bars on full lock (which brings them parallel to the frame top tube) I could still get a 4" bellmouth on my carb,without fouling the 'sausage' on wheels.
Re: MSVA QUERY....
December 06, 2009, 10:00:22 PM »
When the test is carried out you will be sitting on the Trike.
Anything outside that area should have a radius on the edge.
http://www.choppit.co.uk
Re: MSVA QUERY....
December 06, 2009, 10:11:32 PM »
So push your feet to the edge of the pegs and point your knees outward
haggis
Re: MSVA QUERY....
December 07, 2009, 06:10:57 AM »
Quote from: tbone on December 06, 2009, 10:11:32 PM
Yep as tbone sez. Stick ya knees out when sat on it
Re: MSVA QUERY....
December 07, 2009, 07:15:01 AM »
Quote from: haggis on December 07, 2009, 06:10:57 AM
Plus if you think it might cause a problem and it is feasible then remove the offending item and/or replace it with summit else until after the test!
bitzman5
Re: MSVA QUERY....
December 08, 2009, 12:34:06 AM »
HI When i took my kitcar for SVA every time the examiner failed it we asked him HOW HE WOULD DO IT therfore putting him in your place and telling you what he would do to put it right hope this helps
Re: MSVA QUERY....
Reply #6 on:
December 08, 2009, 09:39:38 PM »
Quote from: bitzman5 on December 08, 2009, 12:34:06 AM
well.....was the examiner helpful and did it pass in the end?
bitzman5
Re: MSVA QUERY....
Reply #7 on:
December 09, 2009, 02:37:30 AM »
Yes passed with flying colours
Re: MSVA QUERY....
Reply #8 on:
December 11, 2009, 03:52:44 PM »
congratulations
bitzman5
Re: MSVA QUERY....
Reply #9 on:
December 11, 2009, 06:57:45 PM »
YOU CAN FIND MY BLITZ'S IN THE 4 WHEEL SECTION OF THIS SITE
