February 19, 2026, 12:49:59 AM *
Author Topic: rear disc conversion  (Read 3113 times)
cowboy
at your peril
« on: November 28, 2009, 02:04:09 PM »
Hi Every one .Just a snippet of information regarding disc conversion ,if any one dont know ,or isnt sure .The golf mk4 callipers fit the mk2 carriers
cowboy
« Reply #1 on: November 28, 2009, 10:22:22 PM »
So are they same handbrake config as the MK2's?
« Reply #2 on: November 28, 2009, 11:02:25 PM »
We really ought to sort all this info out once & for all & get it posted on the main site!
Cheers Cowboy.
« Reply #3 on: November 29, 2009, 08:30:12 AM »
Was thinking tht myself! So many different options to go for !
Donut
« Reply #4 on: December 01, 2009, 06:45:30 PM »
Ok so mk4 fits the carrier and a v5 rear caliper uses a 256mm veted disc (22mm thick max and 20 mm min) we are saying that a nova front disc in the Mankey conversion works which is 236mm diameter( and there are 2 thickness of 10mm or 12.8mm and people have had issues getting the correct one to work with the golf gti rear caliper according to some threads)
so my question is has anyone used the mk4 rear caliper with a front nova gte vented disc which is 20mm max? ie the same diameter as the solid disc but suitable for the v5 caliper's thickness
I know that this would not be needed for braking performance but by god would that look that the dogs twitchy thing if you had rear calipers with crossdrilled vented discs or I am being silly
any thoughts problems anyone can see
Donut
« Reply #5 on: December 01, 2009, 06:47:52 PM »
Yeah, your just being silly!!!!!
Donut
« Reply #6 on: December 01, 2009, 07:15:05 PM »
oh I thought it would look good!
would it not be a case of my thing is bigger than your thing!!
« Reply #7 on: December 01, 2009, 07:38:20 PM »
I manage to lock the back end up quite sufficently with the standard drum brakes but would look good.
« Last Edit: December 01, 2009, 07:40:06 PM by TwistedPatience » Logged
« Reply #8 on: December 01, 2009, 07:58:08 PM »
In the interests of shared knowledge Mr Donut, give it a go & post a piccie.  Smiley
When I did my first conversion I just used what was to hand at the time. I'm sure there are plenty of alternatives that'll work just as well, if not better. As Doc says, a good set of standard drums will do the job, so it really is just down to looks. I just think discs look tidier & sportier. If we can compile a list of calipers, carriers & discs that'll hang together we'll post it in the Motors, 3 wheels section of the main site.
