February 19, 2026, 11:59:26 AM *
Author Topic: Recon engines?  (Read 4232 times)
« on: October 28, 2009, 04:19:36 PM »
Anyone ever had a Reliant engine done?
« Reply #1 on: October 28, 2009, 04:31:49 PM »
Don't know of any companies who advertise exchange units, but if anyone does, let us know.
Ska Man worked out a while ago that to replace everything in a Reliant motor -bearings, seals, rings, gaskets etc, would cost about 200 quid. Might well be much more now. Anyone know?
« Reply #2 on: October 28, 2009, 04:37:42 PM »
I know reliant parts world do them ......at a price! £975!plus vat plus delivery!
« Reply #3 on: October 28, 2009, 04:48:51 PM »
Jeez! You could buy a really good quality complete car for that, then flog the axle & stuff to cover some of the costs.
« Reply #4 on: October 28, 2009, 05:11:56 PM »
You can buy a new Zetec for only £650 someone had a stall at the hotrod drags selling em!
« Reply #5 on: October 28, 2009, 05:12:25 PM »
Yeah thats what I thought! Just looked on e bay ..liner set £100...piston set £160..then theres the labour and Id guess £60 plus for bearings...
  The reason Im looking is i just tried to start my engine and as it turned over smoke was puffing out the filler! Also when I turned it over by hand it didnt feel like there was a lot of compression. It appeared to drive ok when I bought it. As usual Im being too critical ,but you know me ..belt and braces an' all that!
« Last Edit: October 28, 2009, 05:16:47 PM by ROD » Logged
« Reply #6 on: October 28, 2009, 05:26:55 PM »
Not a lot of compression in a Reliant anyway. Smoke out of the filler? That's weird.
« Reply #7 on: October 29, 2009, 04:48:25 AM »
I'll see how it runs(when I solve the starting probs!)Could be valve stem oil seals creating smoke.
« Last Edit: October 29, 2009, 04:50:08 AM by ROD » Logged
« Reply #8 on: October 29, 2009, 05:50:15 PM »
 if youve got ,, smoke,, out of the filter    ,and starting problems   it sounds like you have a timimng problem
 i do quite alot with old engine,s that have been stood for years (vintage tractors and the like )  and find that with most  once they have run again and got up to tempreture they settle down and  run  o,k
its normally  rings,, valve,s  etc that get sticky/gummend up..      reliant cylinder liners very rarely need renewing unleess the gudgeon pin circlip has let go and scored the bore.
ive rebuilt quite a few over the years  had more trouble with crankshafts than any other engine  part
« Reply #9 on: October 29, 2009, 06:37:02 PM »
Its only been stood in the dry for about 6 months since run last.
gsxrsam
« Reply #10 on: October 30, 2009, 08:07:45 AM »
www.michaelsofselby.co.uk/
still a reliant dealer and had lots of s/h or new parts last time i rang them....   Wink
gpz
« Reply #11 on: October 30, 2009, 10:46:33 PM »
last tme i was at michaels off selby went out the back and there was several engines dont know if they were good or bad but worth a phone call
