February 19, 2026, 03:03:57 AM
Trike Tech
Golf caliper mounting..........
Topic: Golf caliper mounting.......... (Read 1979 times)
October 18, 2009, 03:59:48 PM »
Im mounting my calipers on plates all as per the Manky ones axle. But I can see that moving the mounting plate so that the caliper will be radially 90 degrees forward,ie in front of the axle centre line instead of behind the axle line ,I can get a better h/brake cable run.Will this be detrimental to braking efficiency,due to being 'leading' as opposed to 'trailing'?
Thanx
snafu
Re: Golf caliper mounting..........
October 18, 2009, 04:44:04 PM »
Leading/trailing brake shoes are more to do with the mechanism operating the brake shoe rather than the orientation. (Lining length, thickness and position can be different on a pair of shoes.)
Link below explains better.
http://books.google.co.uk/books?id=eL6TBaSnd78C&pg=PA553&lpg=PA553&dq=leading+shoe+brake&source=bl&ots=h9X62RVODD&sig=KIT9N5TVOKleOvN8xWm9NNY8ubU&hl=en&ei=zULbSq_PBN_KjAeB0vTlCA&sa=X&oi=book_result&ct=result&resnum=9&ved=0CCgQ6AEwCA#v=onepage&q=leading%20shoe%20brake&f=false
With disc pad system it makes no difference where the pads “clamp” the disc surface.
hth
October 18, 2009, 04:50:54 PM »
yep, caliper position will make no difference to the brake performance, however, think about where the bleed screw will end up.
October 18, 2009, 06:56:14 PM »
Thanks guys . I know about leading trailing shoes.The bleed screw is only slightly out of line from its orig place.
Thanx
