Life is full of compromises and the car is just the same
Before I went to The Shed this weekend, the plan was to put on the front end and make it rolling, but Steve needs to use the shed for a couple of jobs and with the car going to be just under 21 feet it would be awkward for him to move around, so we used Saturday to sort out the tinwork.
Steve had already made the under pan and rear side panels, but had not made the front panels as he did not know how I wanted them due to the shape of the chassis, follow the bends? Or go straight across to the engine plate? I went for the first option, as if the top cover was off, the latter would leave the edges sticking up, which could get damaged when working on the car, this is going to make the top a little harder to make, but not much.
Once we had cut out the panels, we worked out where and how many fasteners we would need and where best they went. This decided, the tabs were welded onto the chassis and the panels were put back on, marked through the tabs and then drilled, we next riveted the springs to the tabs and trial fitted the panels. The fasteners will not be fitted to the panels until after painting.
The Cunning Coupe
The Cunning Coupe
Sunday morning, we put the chassis on stands and levelled it off, the axle was put in, a bar was put through it so we could mark the centres of the wheels to mark for where we need the tubs, we then got the body from out of the other shed and just lowered it on top, we could see it was not going to work. A quick measure of the axle put the top of the tubs 2 inches below the window frame, so it was put the kettle on, sit back and have a rethink.
The only way it was going to work was cut out the roof.
The Cunning Coupe
It was another sit down and then grab the disc cutter and make the first cut, from then on, there was no going back.
After 10 minutes of cutting, the job was done and the body was sitting back over the chassis, we propped it up then walked around adjusting it until I was happy with the way it looked. We marked the centre line of the wheels, drilled a small hole each side and marked for the tubs (They will be round at the top with straight sides down to the bottom.) We marked the bottom front of the body level with the chassis, we then marked where the end of the chassis was, we drew between these, then up at the rear to the end of the body.
The Cunning Coupe
It was another stand back and another look, you know what? I quite like it!!! It was a “compromise” but a good one.
Not only do I think it looks good, but also due to the way it sits, I don’t have to extend it anywhere near 10 inches now, and have decided to extend the bonnet section to the engine plate, so I phoned Paul up and ordered a longer bit of bonnet than I have now.
The Cunning Coupe
It’s the Wild Bunch AGM and I have a couple of MSA seminars next weekend, so will be going up the weekend after. Don’t know what’s planed yet but will update soon after.
(My site has been updated.)
